Introduction
Your Garmin (Model Number: 010-01507-03) Dash Cam 35 is a reliable device that captures high-quality video and audio. If your dash cam's buttons are damaged or unresponsive, you may need to replace a damaged button.
If you see that your dash cam buttons have visible damage or aren't responding to input, the issue is most likely the buttons. A replacement may be necessary if general troubleshooting has not resolved the issue.
In this guide, we'll walk you through a safe replacement of your dash cam battery. A soldering kit will be needed to replace the buttons, which can be hazardous due to the heat. Please use caution during this repair. Repairing the buttons is a more complex process that requires soldering knowledge.
Before starting, make sure you turn off the dash cam and unplug it to avoid any electrical hazards. Back up any vital footage beforehand in case of damage.
Be sure to handle the device carefully, as damage can occur if mishandled. Make sure to follow the guide's steps altogether to avoid damage. If done correctly, you can successfully repair the buttons on your Garmin Dash Cam 35.
Carefully apply heat to the solder joints for the buttons that need to be replaced.
Remove the buttons.
