Garmin Dash Cam 35 Battery Replacement
  1. Garmin Dash Cam 35 Battery Replacement, Case: step 1, image 1 of 1
    • Remove the two 1.7 mm screws holding the case in using a T6 Torx screwdriver.
    Ask FixBot
  2. Garmin Dash Cam 35 Battery Replacement: step 2, image 1 of 1
    • Use opening picks and the opening tool to pry the two pieces of the case apart.
    • Be careful when prying and try not to break anything.
    Ask FixBot
  3. Garmin Dash Cam 35 Battery Replacement: step 3, image 1 of 1
    • Carefully pinch the power cable, and slowly remove it from the motherboard slot.
    Ask FixBot
  4. Garmin Dash Cam 35 Battery Replacement: step 4, image 1 of 1
    • Carefully lift the lock on the motherboard for the ribbon cable. Unslot the ribbon after the lock is undone.
    • Remove the case.
    Ask FixBot
  5. Garmin Dash Cam 35 Battery Replacement, Battery: step 5, image 1 of 1
    • On the battery side of the dash cam, use a T5 Torx screwdriver to remove the two 1.4 mm screws from the battery bracket.
    Ask FixBot
  6. Garmin Dash Cam 35 Battery Replacement: step 6, image 1 of 1
    • Remove the battery bracket from the dash cam case.
    • Lay down the battery holder on a clean, flat surface.
    • The bottom of the battery is glued to the holder.
    • Use isopropyl alcohol between the bracket and battery to soften the glue. Heat can be applied to the glued side of the battery as well.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 177
