Garmin Dash Cam 20 Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
81
All Time:
966
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Garmin Dash Cam 20 Screen Replacement, Internal Assembly: step 1, image 1 of 2 Garmin Dash Cam 20 Screen Replacement, Internal Assembly: step 1, image 2 of 2
      • Be sure to turn off the Dash Cam by pressing the power button.
      Ask FixBot
    2. Garmin Dash Cam 20 Screen Replacement: step 2, image 1 of 2 Garmin Dash Cam 20 Screen Replacement: step 2, image 2 of 2
      • Rotate the Dash Cam to where the socket faces you.
      • Remove the 9 mm screw using the Torx T6 screwdriver.
      Ask FixBot
    3. Garmin Dash Cam 20 Screen Replacement: step 3, image 1 of 2 Garmin Dash Cam 20 Screen Replacement: step 3, image 2 of 2
      • Remove the Dash Cam socket piece.
      Ask FixBot
    4. Garmin Dash Cam 20 Screen Replacement: step 4, image 1 of 2 Garmin Dash Cam 20 Screen Replacement: step 4, image 2 of 2
      • Rotate the Dash Cam to where the product information faces you.
      • Remove the two 5 mm screws using the Torx T5 screwdriver.
      Ask FixBot
    5. Garmin Dash Cam 20 Screen Replacement: step 5, image 1 of 3 Garmin Dash Cam 20 Screen Replacement: step 5, image 2 of 3 Garmin Dash Cam 20 Screen Replacement: step 5, image 3 of 3
      • Remove top case from the bottom case.
      • The compact nature of the casing requires use of the metal spudger for needed leverage.
      Ask FixBot
    6. Garmin Dash Cam 20 Screen Replacement: step 6, image 1 of 3 Garmin Dash Cam 20 Screen Replacement: step 6, image 2 of 3 Garmin Dash Cam 20 Screen Replacement: step 6, image 3 of 3
      • Remove the two 5mm screws using the Torx T5 screwdriver
      • By removing the screws, the metal battery frame will now become free from the rest of the device.
      Ask FixBot
    1. Garmin Dash Cam 20 Screen Replacement, Screen: step 7, image 1 of 3 Garmin Dash Cam 20 Screen Replacement, Screen: step 7, image 2 of 3 Garmin Dash Cam 20 Screen Replacement, Screen: step 7, image 3 of 3
      • Use the Phillips screwdriver to remove the four 5mm screws.
      Ask FixBot
    2. Garmin Dash Cam 20 Screen Replacement: step 8, image 1 of 2 Garmin Dash Cam 20 Screen Replacement: step 8, image 2 of 2
      • Use the metal spudger to remove metal plate from device. This will reveal the screen.
      Ask FixBot
    3. Garmin Dash Cam 20 Screen Replacement: step 9, image 1 of 3 Garmin Dash Cam 20 Screen Replacement: step 9, image 2 of 3 Garmin Dash Cam 20 Screen Replacement: step 9, image 3 of 3
      • Use the metal spudger to remove screen from device.
      Ask FixBot
    4. Garmin Dash Cam 20 Screen Replacement: step 10, image 1 of 1
      • The screen is now detached.
      Ask FixBot
Jesse Hillman
757 Reputation
5 Guides authored
USF Tampa, Team 2-1, Cagle Fall 2016 Member of USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 81
All Time: 966
