Garmin Dash Cam 20 Camera Lens Replacement
  1. Garmin Dash Cam 20 Camera Lens Replacement, Internal Assembly: step 1, image 1 of 2 Garmin Dash Cam 20 Camera Lens Replacement, Internal Assembly: step 1, image 2 of 2
    • Be sure to turn off the Dash Cam by pressing the power button.
    Ask FixBot
  2. Garmin Dash Cam 20 Camera Lens Replacement: step 2, image 1 of 2 Garmin Dash Cam 20 Camera Lens Replacement: step 2, image 2 of 2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
    Ask FixBot
  3. Garmin Dash Cam 20 Camera Lens Replacement: step 3, image 1 of 2 Garmin Dash Cam 20 Camera Lens Replacement: step 3, image 2 of 2
    • Remove the Dash Cam socket piece.
    Ask FixBot
  4. Garmin Dash Cam 20 Camera Lens Replacement: step 4, image 1 of 2 Garmin Dash Cam 20 Camera Lens Replacement: step 4, image 2 of 2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
    Ask FixBot
  5. Garmin Dash Cam 20 Camera Lens Replacement: step 5, image 1 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 5, image 2 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 5, image 3 of 3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
    Ask FixBot
  6. Garmin Dash Cam 20 Camera Lens Replacement: step 6, image 1 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 6, image 2 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 6, image 3 of 3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
    Ask FixBot
  7. Garmin Dash Cam 20 Camera Lens Replacement, Motherboard Components: step 7, image 1 of 2 Garmin Dash Cam 20 Camera Lens Replacement, Motherboard Components: step 7, image 2 of 2
    • This step shows the use of an incorrect tool. Always use an ESD safe tool, like a nylon spudger, when working with delicate internal components.
    • Use the nylon spudger to pry the corner of the case off of the motherboard.
    Ask FixBot
  8. Garmin Dash Cam 20 Camera Lens Replacement: step 8, image 1 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 8, image 2 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 8, image 3 of 3
    • Remove the metal case off of the motherboard.
    Ask FixBot
  9. Garmin Dash Cam 20 Camera Lens Replacement: step 9, image 1 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 9, image 2 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 9, image 3 of 3
    • Remove the battery connection.
    Ask FixBot
  10. Garmin Dash Cam 20 Camera Lens Replacement: step 10, image 1 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 10, image 2 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 10, image 3 of 3
    • Remove the three 5 mm screws using the Torx T5 screwdriver.
    Ask FixBot
  11. Garmin Dash Cam 20 Camera Lens Replacement: step 11, image 1 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 11, image 2 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 11, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the connector on the top right of the motherboard.
    Ask FixBot
  12. Garmin Dash Cam 20 Camera Lens Replacement: step 12, image 1 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 12, image 2 of 3 Garmin Dash Cam 20 Camera Lens Replacement: step 12, image 3 of 3
    • Remove the motherboard from the case and flip to reveal SD connection.
    • Use tweezers to remove the connector next to the SD card slot.
    Ask FixBot
  13. Garmin Dash Cam 20 Camera Lens Replacement: step 13, image 1 of 1
    • The motherboard is now removed aside from the copper strip and its connector.
    • Disconnect from the front case and the copper strip.
    Ask FixBot
  14. Garmin Dash Cam 20 Camera Lens Replacement, Camera Lens: step 14, image 1 of 2 Garmin Dash Cam 20 Camera Lens Replacement, Camera Lens: step 14, image 2 of 2
    • Use the Torx T5 screwdriver to remove the two 5mm screws.
    • These screws hold the camera in place. Therefore, the lens will fall into the bottom case.
    Ask FixBot
  15. Garmin Dash Cam 20 Camera Lens Replacement: step 15, image 1 of 1
    • The camera lens is now detached.
    Ask FixBot
Jesse Hillman
757 Reputation
5 Guides authored
USF Tampa, Team 2-1, Cagle Fall 2016 Member of USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 42
All Time: 1,439
