Up to 20% off select tools
Garmin Approach S2 Screen Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
72
All Time:
1,351
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
In this guide there are delicate parts that will very easily break under tension. Keep this in mind as your move forwards.
    1. Garmin Approach S2 Screen Replacement, Back Cover: step 1, image 1 of 2 Garmin Approach S2 Screen Replacement, Back Cover: step 1, image 2 of 2
      • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
      Ask FixBot
    2. Garmin Approach S2 Screen Replacement: step 2, image 1 of 1
      • Remove the back cover carefully.
      • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
      Ask FixBot
    1. Garmin Approach S2 Screen Replacement, Water Proof Gasket: step 3, image 1 of 1
      • Remove the orange gasket.
      Ask FixBot
    1. Garmin Approach S2 Screen Replacement, Screen: step 4, image 1 of 1
      • Remove the screen and motherboard assembly from the case.
      Ask FixBot
    2. Garmin Approach S2 Screen Replacement: step 5, image 1 of 1
      • Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
      Ask FixBot
    3. Garmin Approach S2 Screen Replacement: step 6, image 1 of 1
      • Remove the screen from the golden metal clip.
      Ask FixBot
    4. Garmin Approach S2 Screen Replacement: step 7, image 1 of 1
      • Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
      Ask FixBot
    5. Garmin Approach S2 Screen Replacement: step 8, image 1 of 2 Garmin Approach S2 Screen Replacement: step 8, image 2 of 2
      • Remove the connector from the motherboard by pulling it free at the base.
      • Make sure to pull from the base of the connector wire, as it is very easy to rip the wire from the screen.
      Ask FixBot
    6. Garmin Approach S2 Screen Replacement: step 9, image 1 of 1
      • Remove the screen from the motherboard.
      • Notice our tape retaining the connector to the screen. This is so easy to rip!
      Ask FixBot
Author
with
Evan Miller
253 Reputation
2 Guides authored
IUPUI, Team S4-G1, Baechle Spring 2018 Member of IUPUI, Team S4-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G1
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 72
All Time: 1,351
