Up to 20% off select tools
Garmin Approach S2 Battery Replacement
Views: 48K
View statistics:
Past 24 Hours:
8
Past 7 Days:
59
Past 30 Days:
288
All Time:
47,509
Comments: 13
5 comments on steps, 8 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
This guide directs the user in removing the back cover and battery. Keep in mind that this replacement requires generous prying and a consideration of tiny and delicate parts.
    1. Garmin Approach S2 Battery Replacement, Back Cover: step 1, image 1 of 2 Garmin Approach S2 Battery Replacement, Back Cover: step 1, image 2 of 2
      • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
      Ask FixBot
    2. Garmin Approach S2 Battery Replacement: step 2, image 1 of 1
      • Remove the back cover carefully.
      • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
      Ask FixBot
    1. Garmin Approach S2 Battery Replacement, Battery: step 3, image 1 of 1
      • On the back cover use a plastic opening tool to remove the green tape retaining the battery.
      Ask FixBot
    2. Garmin Approach S2 Battery Replacement: step 4, image 1 of 2 Garmin Approach S2 Battery Replacement: step 4, image 2 of 2
      • Remove the green tape shrouding the battery connector.
      Ask FixBot
    3. Garmin Approach S2 Battery Replacement: step 5, image 1 of 2 Garmin Approach S2 Battery Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use the ESD safe tweezers to push the connector and metal shroud out from the back of the connector.
      • Remove the third and fourth wires from the right of the connector (as seen when looking from the angle in the photo). They should be red and black respectively.
      • DO NOT attempt to pull the wire from the connector, it will pull the wire from the metal shroud shown in the red box, which needs to be preserved for the connection to be successful.
      Ask FixBot
    4. Garmin Approach S2 Battery Replacement: step 6, image 1 of 1
      • Use the ESD safe tweezers to break the adhesive between the back cover and the battery.
      • Remove the battery.
      Ask FixBot
    5. Garmin Approach S2 Battery Replacement: step 7, image 1 of 1
      • Remove the green tape on the back of the battery, it can be reused later.
      Ask FixBot
7 other people completed this guide.
Author
with
Emily Kovacs
280 Reputation
1 Guide authored
IUPUI, Team S4-G1, Baechle Spring 2018 Member of IUPUI, Team S4-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G1
3 Members
36 Guides authored
8 Guide Comments
If anyone is looking for the replacement battery for the Approach S2 it can be found here:
Replacement Battery for Garmin Approach S2
It also included the T5 Torx and Opening Tools that are needed.
michaelf33707 - Reply Share
Step 6 shows 2 red wires each with a free end. One of these red wires has the non free end connected to the charging circuit terminal but there is no mention in Step 6 of disconnecting this wire or where the free end is connected to.
Paul Stevenson - Reply Share
This is a great tutorial for the S2. In my case I accidentally dropped one metal shroud (referred to in Step 5). I scoured the area on my hands and knees to no avail. Can you direct me to where I might obtain this part?or perhaps the entire connector? Thank you….
Brian Mahoney - Reply Share
Hi, Where the !&&* Can I buy a Replacement Battery for The Garmin S2 Golf watch.????.
Gregory John Wickenden - Reply Share
Gregory, I got my replacement via Amazon (UK). Battery came from Germany in about 1 week. Not cheap, but a lot cheaper than a new watch.
john.joice - Reply Share
Past 24 Hours: 8
Past 7 Days: 59
Past 30 Days: 288
All Time: 47,509
