Up to 20% off select tools
Garbage Disposal Replacement
Views: 8.5K
View statistics:
Past 24 Hours:
8
Past 7 Days:
47
Past 30 Days:
234
All Time:
8,478
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 30 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
Garbage disposals can run into problems when built-up waste accumulates over time. It is important that one has a fully functional garbage disposal to drain correctly and to rid one’s sink of waste. This guide will show you how to replace a garbage disposal in 10 minutes or less!
    1. Garbage Disposal Replacement, Garbage Disposal: step 1, image 1 of 1
      • Before installing your garbage disposal, make sure both your pipes and garbage disposal mount (pictured at the top) are aligned correctly to support your model.
      Ask FixBot
    2. Garbage Disposal Replacement: step 2, image 1 of 1
      • Attach your garbage disposal to the mount (circled) that is attached to the sink hole.
      Ask FixBot
    3. Garbage Disposal Replacement: step 3, image 1 of 1
      • Connect the silver mounting hardware attached to the top of the garbage disposal by turning it clockwise.
      • Mount disposal to the sink using one hand to lift it and the other to attach to the silver mounting hardware while making sure to match the grooves of your disposal into the mount. The disposal should now be all in one piece.
      Ask FixBot
    4. Garbage Disposal Replacement: step 4, image 1 of 3 Garbage Disposal Replacement: step 4, image 2 of 3 Garbage Disposal Replacement: step 4, image 3 of 3
      • After mounting the disposal in place, align the black disposal pipe with the white PVC pipe connected to the sink.
      Ask FixBot
    5. Garbage Disposal Replacement: step 5, image 1 of 1
      • Connect the dishwasher drain tube to the garbage disposable.
      Ask FixBot
    6. Garbage Disposal Replacement: step 6, image 1 of 1
      • Once everything is in place, tighten all of your tube rings to ensure no leakage occurs.
      Ask FixBot
    7. Garbage Disposal Replacement: step 7, image 1 of 1
      • Install and plug electrical wire into the correct power source. Test your disposal switch and check for any signs of leakage.
      Ask FixBot
Be sure to test your garbage disposal before sending any waste down the drain. Happy disposing!
5 other people completed this guide.
Author
with
Annie Chan
289 Reputation
1 Guide authored
1 Guide Comment
There is a tiny hose that attaches to an air compressor. It keeps falling off.
Nancy Raza - Reply Share
Past 24 Hours: 8
Past 7 Days: 47
Past 30 Days: 234
All Time: 8,478
