Introduction
If the triggers of your Gamesir X4 Aileron are not responding, then this guide is for you. First make sure to check out our troubleshooting page for this issue using this link, Gamesir X4 Aileron Triggers Not Responding.
If your problem persists please use this guide to complete the replacement. The triggers can be replaced once each side's components have been fully removed. The procedure is simple and only requires very simple prying tools and a small Phillips head screwdriver.
Use a hairdryer to heat the rubber grips to soften the adhesive securing them to the back cover.
Using a Jimmy and your hands to pry and remove rubber covering from the back plate.
Disconnect the battery connector by lifting it straight up and out of its socket.
Use a Phillips screwdriver to remove the five 7.2 mm screws securing the right rocker board.
Flip up both of the black locking flaps securing the two ribbon cables.
Disconnect the ribbon cables.
Flip up the two black locking flaps securing the two white ribbon cables.
Disconnect the two ribbon cables.
Pull the white connector directly up and out to disconnect it from its socket.
Using the Jimmy tool, pry outwards against the plastic shell to release the trigger from housing.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
