Gamesir X4 Aileron Battery Replacement
  1. Gamesir X4 Aileron Battery Replacement, Back Cover: step 1, image 1 of 1
    • Use a hairdryer to heat the rubber grips to soften the adhesive securing them to the back cover.
    • Using a Jimmy and your hands to pry and remove rubber covering from the back plate.
    • The rubber may become deformed and challenging to reinstall.
    Ask FixBot
  2. Gamesir X4 Aileron Battery Replacement: step 2, image 1 of 1
    • Use a Jimmy to pry up and remove the small back cover off to gain access to the screws.
    • There is a small hole at the bottom side of the panel that can be used as leverage for prying it open.
    • Slowly work your way around with the Jimmy to work the panel off.
    Ask FixBot
  3. Gamesir X4 Aileron Battery Replacement: step 3, image 1 of 1
    • Use your hand/Jimmy to take the sticker off of the front of each controller to access the screws behind it.
    Ask FixBot
  4. Gamesir X4 Aileron Battery Replacement: step 4, image 1 of 2 Gamesir X4 Aileron Battery Replacement: step 4, image 2 of 2
    • Use a Phillips screwdriver to remove all six 7.2 mm screws. securing the back cover.
    • There are two screws under the small back cover and four screws under the sticker on to the front.
    Ask FixBot
  5. Gamesir X4 Aileron Battery Replacement: step 5, image 1 of 3 Gamesir X4 Aileron Battery Replacement: step 5, image 2 of 3 Gamesir X4 Aileron Battery Replacement: step 5, image 3 of 3
    • Use a Jimmy to pry the entire controller in half to separate the 2 components. Slowly work your way around the controller, working the Jimmy through the separate the halves.
    • Take care not to strain or damage the connected ribbon cable.
    • Flip up the black locking flap securing the ribbon cable.
    • Disconnect the ribbon cable.
    Ask FixBot
  6. Gamesir X4 Aileron Battery Replacement: step 6, image 1 of 1
    • Repeat all above steps for other side of the controller if needed.
    Ask FixBot
  7. Gamesir X4 Aileron Battery Replacement, Battery: step 7, image 1 of 1
    • Disconnect the battery connector by lifting it straight up and out of its socket.
    Ask FixBot
  8. Gamesir X4 Aileron Battery Replacement: step 8, image 1 of 1
    • Pull out the battery by hand.
    • The battery is secured with a mild adhesive.
    Ask FixBot
  9. Gamesir X4 Aileron Battery Replacement: step 9, image 1 of 2 Gamesir X4 Aileron Battery Replacement: step 9, image 2 of 2
    • Repeat the procedure for the other side if necessary.
    Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 62
All Time: 179
