Gameboy Advance AGS-101 Blacklight Mod
    1. Gameboy Advance AGS-101 Blacklight Mod, Game Boy Advance Teardown: step 1, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod, Game Boy Advance Teardown: step 1, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod, Game Boy Advance Teardown: step 1, image 3 of 3
      • Remove the back battery cover by pinching down on the tab and pulling outward.
      Ask FixBot
    2. Gameboy Advance AGS-101 Blacklight Mod: step 2, image 1 of 1
      • Remove the six back panel screws using a Y1 screw driver.
      Ask FixBot
    3. Gameboy Advance AGS-101 Blacklight Mod: step 3, image 1 of 1
      • Remove bottom back panel screw with a Phillips #1 screw driver.
      Ask FixBot
    4. Gameboy Advance AGS-101 Blacklight Mod: step 4, image 1 of 1
      • Remove the back panel by pulling away with one hand and the front secured in the other hand.
      • Beware of right and left triggers, the right and left panels, and the power switch falling off as the back panel is removed.
      Ask FixBot
    5. Gameboy Advance AGS-101 Blacklight Mod: step 5, image 1 of 2 Gameboy Advance AGS-101 Blacklight Mod: step 5, image 2 of 2
      • Remove left and right triggers by lifting and pulling them away from the system.
      • Do the same for side panels.
      • For finicky or jammed triggers only. Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
      Ask FixBot
    6. Gameboy Advance AGS-101 Blacklight Mod: step 6, image 1 of 2 Gameboy Advance AGS-101 Blacklight Mod: step 6, image 2 of 2
      • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
      Ask FixBot
    7. Gameboy Advance AGS-101 Blacklight Mod: step 7, image 1 of 1
      • Remove the three screws on the circuit board with a Phillips #1 screw driver.
      • The last screw on the right is not included on some Game Boy Advance systems.
      Ask FixBot
    8. Gameboy Advance AGS-101 Blacklight Mod: step 8, image 1 of 2 Gameboy Advance AGS-101 Blacklight Mod: step 8, image 2 of 2
      • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
      • Beware not to damage the top ribbon by pulling up gently.
      Ask FixBot
    9. Gameboy Advance AGS-101 Blacklight Mod: step 9, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod: step 9, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the rubber button pads from their pockets.
      • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
      Ask FixBot
    10. Gameboy Advance AGS-101 Blacklight Mod: step 10, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod: step 10, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod: step 10, image 3 of 3
      • Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
      • Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
      Ask FixBot
    11. Gameboy Advance AGS-101 Blacklight Mod: step 11, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod: step 11, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod: step 11, image 3 of 3
      • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
      • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
      • You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
      Ask FixBot
    12. Gameboy Advance AGS-101 Blacklight Mod: step 12, image 1 of 1
      • Use the tweezers to remove the black tape if needed.
      Ask FixBot
    1. Gameboy Advance AGS-101 Blacklight Mod, Cut the plastic from the shell: step 13, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod, Cut the plastic from the shell: step 13, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod, Cut the plastic from the shell: step 13, image 3 of 3
      • Cut the plastic from the shell, aligned with red markers.
      • Use a cutter to cut the big pieces of plastic.
      • Use the cutter again to cut some plastic from the shell. This is required for the LCD to fit properly.
      • Only cut the plastic that sticks out! It's possible that the red markers are not 100% accurate. (For models with a motherboard serial number beginning with 1, there is normally no need to cut the plastic on the right side).
      • First things first, there are 2 GBA models. 32 pin motherboards and 40 pin motherboards, before you order anything, make sure which model you have. The GBA's starting with a 0 is a 40 pin, if it start with a 1 it's a 32 pin. Please advise Google if you are not sure which model you have.
      Ask FixBot
    2. Gameboy Advance AGS-101 Blacklight Mod, Make it flat: step 14, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod, Make it flat: step 14, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod, Make it flat: step 14, image 3 of 3
      • Use a knife or a flathead screwdriver to flatten it. Make it as flat as possible and take all the plastic away.
      • Do this for all sides which you have cut before.
      Ask FixBot
    3. Gameboy Advance AGS-101 Blacklight Mod, Fit the screen: step 15, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod, Fit the screen: step 15, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod, Fit the screen: step 15, image 3 of 3
      • Inspect if everything is cut and if everything is flat. If it looks good, then proceed!
      • Don't worry about the front. Most of the times the front is still good, the cutting at the back side won't be visible when everything is in. But please check before you proceed.
      • Test if the screen sits flush.
      • Make sure that the screen fits good. There is not a lot of space in the shell. If you proceed anyway, you could damage the screen. Cut some more plastic if needed.
      Ask FixBot
    4. Gameboy Advance AGS-101 Blacklight Mod, Attach lens: step 16, image 1 of 2 Gameboy Advance AGS-101 Blacklight Mod, Attach lens: step 16, image 2 of 2
      • Place a new lens in the shell.
      • It should look like the 2nd picture. It should be attached with the tape that's already on the lens. Make sure that the lens is clean and not damaged!
      Ask FixBot
    5. Gameboy Advance AGS-101 Blacklight Mod, Place the screen in the shell: step 17, image 1 of 2 Gameboy Advance AGS-101 Blacklight Mod, Place the screen in the shell: step 17, image 2 of 2
      • Now take the plastic foil from the screen.
      • Put the screen in the shell.
      • You can attach some double sided tape in the corners of the screen to make it fit easier (make sure it's thin) it's not required. Remember not to touch the screen when the plastic security foil is removed.
      Ask FixBot
    6. Gameboy Advance AGS-101 Blacklight Mod, Place the buttons: step 18, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod, Place the buttons: step 18, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod, Place the buttons: step 18, image 3 of 3
      • Place the buttons in the shell.
      • Place the start/select rubber in the shell.
      Ask FixBot
    7. Gameboy Advance AGS-101 Blacklight Mod, Place rubbers: step 19, image 1 of 2 Gameboy Advance AGS-101 Blacklight Mod, Place rubbers: step 19, image 2 of 2
      • Put the rubbers in.
      • You can also place the L/R buttons in already, but it won't be a problem to do this later if you want.
      Ask FixBot
    8. Gameboy Advance AGS-101 Blacklight Mod, Fold the LCD cable: step 20, image 1 of 2 Gameboy Advance AGS-101 Blacklight Mod, Fold the LCD cable: step 20, image 2 of 2
      • Fold the LCD cable in a "Z" form. The cable is too long, this needs to be done, otherwise it won't fit.
      Ask FixBot
    9. Gameboy Advance AGS-101 Blacklight Mod, Install the adapter: step 21, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod, Install the adapter: step 21, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod, Install the adapter: step 21, image 3 of 3
      • Now it's a good time to take the adapter with you!
      • Plug the LCD cable in the ZIF socket as displayed in the 2nd picture.
      • Fold the LCD cable in the "Z" form again and place the adapter on the screen as displayed in the 3rd picture.
      Ask FixBot
    10. Gameboy Advance AGS-101 Blacklight Mod, Attach tape if needed: step 22, image 1 of 2 Gameboy Advance AGS-101 Blacklight Mod, Attach tape if needed: step 22, image 2 of 2
      • Usually there is tape on the bracket, but if not, just place some anti-electrical tape to secure it.
      • Don't forget to fold the cable in the "Z" form.
      Ask FixBot
    11. Gameboy Advance AGS-101 Blacklight Mod, Place motherboard back in: step 23, image 1 of 2 Gameboy Advance AGS-101 Blacklight Mod, Place motherboard back in: step 23, image 2 of 2
      • Place the motherboard in. WHEN the motherboard is at place, then proceed.
      • Put the screws back in, highlighted in red.
      • Some models have a third screw.
      • The 2nd picture shows when everything is in place with the screws in.
      Ask FixBot
    12. Gameboy Advance AGS-101 Blacklight Mod, Attach ribbon cable: step 24, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod, Attach ribbon cable: step 24, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod, Attach ribbon cable: step 24, image 3 of 3
      • Open the ZIF connector again and put the cable back in.
      • If the cable won't fit, please check your adapter and repeat step 21.
      • Close the ZIF connector with the LCD ribbon cable in. Make sure the red cable from the adapter is at it's place as shown in the 2nd picture.
      • The 3rd picture shows how it needs to be.
      Ask FixBot
    13. Gameboy Advance AGS-101 Blacklight Mod, Solder the red cable: step 25, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod, Solder the red cable: step 25, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod, Solder the red cable: step 25, image 3 of 3
      • This is the pin you need! It's the LEFT leg of DA1 !
      • Put tape on the other IC's. Just to prevent bridges and just to be sure that you have the correct pin.
      • Solder the red cable to the LEFT leg of DA1.
      Ask FixBot
    14. Gameboy Advance AGS-101 Blacklight Mod, Route cable and place buttons: step 26, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod, Route cable and place buttons: step 26, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod, Route cable and place buttons: step 26, image 3 of 3
      • Route the cable as shown in picture 1.
      • The 2nd picture shows when it's all good and finished.
      • Now place the bumpers and the L/R buttons (if not done earlier). Don't forget to place the on/off button back too!
      Ask FixBot
    15. Gameboy Advance AGS-101 Blacklight Mod, Place back cover and test: step 27, image 1 of 3 Gameboy Advance AGS-101 Blacklight Mod, Place back cover and test: step 27, image 2 of 3 Gameboy Advance AGS-101 Blacklight Mod, Place back cover and test: step 27, image 3 of 3
      • Place the backplate back and put the screws back in.
      • That's it! If everything is done it should work now. Have fun gaming!
      Ask FixBot
That’s it! If everything went as it should, you can play the GBA/GBC/GB games with your blacklight screen!
5 other people completed this guide.
koppie007
53,032 Reputation
9 Guides authored
11 Guide Comments
How would I add a way to control the brightness? is it as simple as soldering in an extra chip and wire?
Rinchanlife - Reply Share
Hi!
No, you can’t control the brightness with this mod. But I will try to create the IPS mod guide soon (hopefully next week)! With the IPS screen mod, you can control the brightness. But… you need to solder 3 wires. One on the TP2, and the other 2 cables for R and L buttons. You need to hold select, and press R and L to increase and decrease the brightness.
The IPS screen is a different screen with a special adapter. I’ll try to create the guide soon.
Perhaps it’s possible with another adapter for controlling the brightness on the AGS-101, but I don’t have this kind of adapter.
koppie007 - Reply Share
Hi there again!
Just finished the IPS mod guide!
Link: Game Boy Advance IPS Backlight mod
If you have questions/need help, please let me know.
Good luck!!
Do the ips v2 mod and the ags 101 mod require the same amount of plastic cutting?
D.J. Haynes - Reply Share
Hi! No. The IPS v2 mod takes less amount plastic cutting. But it’s different (for the plastic that needs a cut) regarding the AGS-101 mod.
Past 24 Hours: 6
Past 7 Days: 48
Past 30 Days: 199
All Time: 17,156
