GameSir X5 Lite D-Pad Replacement
    1. GameSir X5 Lite D-Pad Replacement, D-Pad: step 1, image 1 of 3 GameSir X5 Lite D-Pad Replacement, D-Pad: step 1, image 2 of 3 GameSir X5 Lite D-Pad Replacement, D-Pad: step 1, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four 8 mm-long Phillips screws located on the back cover.
      Ask FixBot
    2. GameSir X5 Lite D-Pad Replacement: step 2, image 1 of 1
      • Fully extend the controller and remove the six 5 mm-long Phillip #00 screws off the back of the extender.
      Ask FixBot
    3. GameSir X5 Lite D-Pad Replacement: step 3, image 1 of 1
      • Use an opening pick to loosen the back cover to reach the end of the extender.
      Ask FixBot
    4. GameSir X5 Lite D-Pad Replacement: step 4, image 1 of 2 GameSir X5 Lite D-Pad Replacement: step 4, image 2 of 2
      • Pull the extender to remove the last two 5 mm-long Phillips #00 screws.
      • Remove the springs to separate the two sides of the controller
      Ask FixBot
    5. GameSir X5 Lite D-Pad Replacement: step 5, image 1 of 2 GameSir X5 Lite D-Pad Replacement: step 5, image 2 of 2
      • Flip up the black locking flap securing the white ribbon cable.
      • Disconnect the ribbon cable.
      • Loosen the three 7 mm-long Phillips #00 screws where the triggers are located.
      • The three 7 mm-long Phillips screws where the triggers are located will not be separated, only loosened.
      Ask FixBot
    6. GameSir X5 Lite D-Pad Replacement: step 6, image 1 of 2 GameSir X5 Lite D-Pad Replacement: step 6, image 2 of 2
      • Remove the rubber membrane behind the d-pad.
      Ask FixBot
    7. GameSir X5 Lite D-Pad Replacement: step 7, image 1 of 2 GameSir X5 Lite D-Pad Replacement: step 7, image 2 of 2
      • Remove the d-pad.
      • The d-pad itself measures 2 by 3 centimeters.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 82
Past 30 Days: 376
All Time: 964
