GameSir X2s Type-C Right Trigger Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
54
All Time:
342
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Moderate
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Scenic Route
This guide's procedure isn't the most efficient way to get the job done, but still may be useful in some circumstances.
Introduction
Go to step 1 ↓
This guide covers how to replace the right trigger (RT) on the GameSir X2s Type-C Mobile.
The right trigger is typically used for primary actions such as firing, accelerating, or activating abilities. Replacing the right trigger restores accurate and responsive control.
Tools
    1. GameSir X2s Type-C Right Trigger Replacement, Back: step 1, image 1 of 2 GameSir X2s Type-C Right Trigger Replacement, Back: step 1, image 2 of 2
      • Use a 000 Phillips screwdriver to remove the following eight silver fine-thread 6mm screws.
      • Flip the controller upright.
      Ask FixBot
    2. GameSir X2s Type-C Right Trigger Replacement: step 2, image 1 of 3 GameSir X2s Type-C Right Trigger Replacement: step 2, image 2 of 3 GameSir X2s Type-C Right Trigger Replacement: step 2, image 3 of 3
      • Remove the four silver fine-thread 4.5mm screws under the rubber grip using the 000 Phillips screwdriver.
      • Flip the GameSir X2s Type-C to the back.
      • Using a prying tool around the lip, where both pieces of plastic meet, run that around the hold device.
      • Pop off the plastic piece attached to the device.
      Ask FixBot
    3. GameSir X2s Type-C Right Trigger Replacement: step 3, image 1 of 3 GameSir X2s Type-C Right Trigger Replacement: step 3, image 2 of 3 GameSir X2s Type-C Right Trigger Replacement: step 3, image 3 of 3
      • Remove the blue strip connected to the board.
      • Remove six silver fine-thread 4.5mm screws and the two black fine-thread 4.5mm screws using a 000 Phillips screwdriver.
      • Remove the gold strip connected to the board.
      Ask FixBot
    4. GameSir X2s Type-C Right Trigger Replacement: step 4, image 1 of 3 GameSir X2s Type-C Right Trigger Replacement: step 4, image 2 of 3 GameSir X2s Type-C Right Trigger Replacement: step 4, image 3 of 3
      • Remove the three black fine-thread 4.5mm screws using the 000 Phillips screwdriver.
      • Remove the red and black wires from the board.
      • Remove the board from the GameSir X2s Type-C.
      Ask FixBot
    5. GameSir X2s Type-C Right Trigger Replacement: step 5, image 1 of 3 GameSir X2s Type-C Right Trigger Replacement: step 5, image 2 of 3 GameSir X2s Type-C Right Trigger Replacement: step 5, image 3 of 3
      • Remove the 3 black fine-thread 4.5mm screws from behind the right trigger using a 000 Phillips screwdriver.
      • Remove the 3 black fine-thread 4.5mm screws from the board using a 000 Phillips screwdriver.
      Ask FixBot
    6. GameSir X2s Type-C Right Trigger Replacement: step 6, image 1 of 1
      • Remove the black electrical board from the GameSir X2s Type-C.
      Ask FixBot
    1. GameSir X2s Type-C Right Trigger Replacement, Right Trigger: step 7, image 1 of 2 GameSir X2s Type-C Right Trigger Replacement, Right Trigger: step 7, image 2 of 2
      • Remove three black fine-thread screws with 000 Phillips screwdriver.
      • Replace trigger
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 54
All Time: 342
