Up to 20% off select tools
GameSir X2 Pro Trigger Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
116
All Time:
423
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The trigger is a button on the top of the GameSir X2 Pro. It allows a user to produce various outputs depending on the game.
You may need to replace the trigger if it is unresponsive to input or the response is lagging.
If you need to replace the left trigger on your controller, follow this guide.
    1. GameSir X2 Pro Trigger Replacement, Trigger: step 1, image 1 of 1
      • Insert the tip of the Jimmy between the rubber pad and the back of the controller, then slide it along the edge to loosen the adhesive and lift the pad away.
      • Gently remove the rubber pad.
      Ask FixBot
    2. GameSir X2 Pro Trigger Replacement: step 2, image 1 of 2 GameSir X2 Pro Trigger Replacement: step 2, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the four 4.5 mm screws under the rubber pad.
      Ask FixBot
    3. GameSir X2 Pro Trigger Replacement: step 3, image 1 of 2 GameSir X2 Pro Trigger Replacement: step 3, image 2 of 2
      • Flip the controller over so the back is facing up.
      • Remove the eight 6.0 mm T6 Torx screws from the back of the device.
      Ask FixBot
    4. GameSir X2 Pro Trigger Replacement: step 4, image 1 of 3 GameSir X2 Pro Trigger Replacement: step 4, image 2 of 3 GameSir X2 Pro Trigger Replacement: step 4, image 3 of 3
      • Use the Jimmy to pry the back cover of the controller, following the seam.
      • Some force is necessary, but be careful not to damage any of the clips holding the controller together.
      Ask FixBot
    5. GameSir X2 Pro Trigger Replacement: step 5, image 1 of 3 GameSir X2 Pro Trigger Replacement: step 5, image 2 of 3 GameSir X2 Pro Trigger Replacement: step 5, image 3 of 3
      • Remove the six 4.5 mm screws from under the back panel with a Phillips #000 screwdriver.
      Ask FixBot
    6. GameSir X2 Pro Trigger Replacement: step 6, image 1 of 3 GameSir X2 Pro Trigger Replacement: step 6, image 2 of 3 GameSir X2 Pro Trigger Replacement: step 6, image 3 of 3
      • Use a Phillips #000 screwdriver to remove the three 4.5 mm screws securing the joystick board in the corner.
      Ask FixBot
    7. GameSir X2 Pro Trigger Replacement: step 7, image 1 of 3 GameSir X2 Pro Trigger Replacement: step 7, image 2 of 3 GameSir X2 Pro Trigger Replacement: step 7, image 3 of 3
      • Remove the four 4.5 mm Phillips #000 screws securing the circuit board behind the joystick board that was just removed.
      • Remove the board from the frame.
      Ask FixBot
    8. GameSir X2 Pro Trigger Replacement: step 8, image 1 of 1
      • Remove the trigger from the corner above the action buttons.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Sean Brady
653 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 116
All Time: 423
