GameSir X2 Pro Joystick Replacement
    1. GameSir X2 Pro Joystick Replacement, Joystick: step 1, image 1 of 1
      • Insert the tip of the Jimmy between the rubber pad and the back of the controller, then slide it along the edge to loosen the adhesive and lift the pad away.
      • Gently remove the rubber pad.
      Ask FixBot
    2. GameSir X2 Pro Joystick Replacement: step 2, image 1 of 2 GameSir X2 Pro Joystick Replacement: step 2, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the four 4.5 mm screws under the rubber pad.
      Ask FixBot
    3. GameSir X2 Pro Joystick Replacement: step 3, image 1 of 2 GameSir X2 Pro Joystick Replacement: step 3, image 2 of 2
      • Flip the controller over so the back is facing up.
      • Remove the eight 6.0 mm T6 Torx screws from the back of the device.
      Ask FixBot
    4. GameSir X2 Pro Joystick Replacement: step 4, image 1 of 3 GameSir X2 Pro Joystick Replacement: step 4, image 2 of 3 GameSir X2 Pro Joystick Replacement: step 4, image 3 of 3
      • Use the Jimmy to pry the back cover of the controller, following the seam.
      • Some force is necessary, but be careful not to damage any of the clips holding the controller together.
      Ask FixBot
    5. GameSir X2 Pro Joystick Replacement: step 5, image 1 of 3 GameSir X2 Pro Joystick Replacement: step 5, image 2 of 3 GameSir X2 Pro Joystick Replacement: step 5, image 3 of 3
      • Remove the six 4.5 mm screws from the back panel with a Phillips #000 screwdriver.
      Ask FixBot
    6. GameSir X2 Pro Joystick Replacement: step 6, image 1 of 3 GameSir X2 Pro Joystick Replacement: step 6, image 2 of 3 GameSir X2 Pro Joystick Replacement: step 6, image 3 of 3
      • Use a Phillips #000 screwdriver to remove the three 4.5 mm screws securing the joystick board in the corner.
      • Pull the board with the joystick attached from the case to remove it.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Sean Brady
653 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 63
All Time: 174
