Introduction
This guide goes over how to replace the vibration motor on a GameSirT4 Pro controller. If the motors are not vibrating, vibrating too violently, or other issues are happening, this guide covers the proper removal and reinstallation of the vibration motors.
Remove the following screws on the back case using a Phillips screwdriver:
Two 9.2 mm
Two 11.3 mm
Insert an opening tool in the seam between the front and back case.
Pry around the perimeter until the back case releases.
