Introduction
Go to step 1 ↓This guide goes over how to replace the motherboard on a GameSirT4 Pro controller. If your controller is having major problems with multiple components, replacing the motherboard may solve the problem.
Tools
Remove the following screws on the back case using a Phillips screwdriver:
Two 9.2 mm
Two 11.3 mm
Insert an opening tool in the seam between the front and back case.
Pry around the perimeter until the back case releases.
