GameSir T4 Pro Bumper Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
23
Past 30 Days:
90
All Time:
1,942
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide goes over how to replace the bumpers, otherwise known as shoulder buttons, on a GameSirT4 Pro controller. If your shoulder buttons are getting stuck, cracked, or unresponsive this guide shows how to remove and replace the shoulder buttons.
Tools
    1. GameSir T4 Pro Bumper Replacement, Bumper: step 1, image 1 of 3 GameSir T4 Pro Bumper Replacement, Bumper: step 1, image 2 of 3 GameSir T4 Pro Bumper Replacement, Bumper: step 1, image 3 of 3
      • Remove the following screws on the back case using a Phillips screwdriver:
      • Two 9.2 mm
      • Two 11.3 mm
      • Insert an opening tool in the seam between the front and back case.
      • Pry around the perimeter until the back case releases.
      Ask FixBot
    2. GameSir T4 Pro Bumper Replacement: step 2, image 1 of 1
      • Disconnect the USB-C charger with tweezers.
      • Do not pull on the wires.
      Ask FixBot
    3. GameSir T4 Pro Bumper Replacement: step 3, image 1 of 2 GameSir T4 Pro Bumper Replacement: step 3, image 2 of 2
      • Remove the two 7.1 mm Phillips screws that secure the shoulder buttons.
      Ask FixBot
    4. GameSir T4 Pro Bumper Replacement: step 4, image 1 of 1
      • Gently lift up the plastic piece holding the bumper and trigger.
      • Remove the bumper.
      Ask FixBot
Yamini Sri
355 Reputation
3 Guides authored
IUPUI, Team 1-2, Harley Spring 2024 Member of IUPUI, Team 1-2, Harley Spring 2024
IUPUI-HARLEY-S24S1G2
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 90
All Time: 1,942
