GameSir T4 Pro Battery Replacement
Views: 5.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
141
All Time:
5,331
Comments: 3
3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove the battery from your GameSit T4 Pro controller. All you need for this repair is a Phillips #1 screwdriver and the iFixit opening tool. For the battery replacement, this controller requires a 600 maH battery. Complete this repair guide before continuing to the other repair guides.
Parts
Tools
    1. GameSir T4 Pro Battery Replacement, Battery: step 1, image 1 of 1
      • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
      Ask FixBot
    2. GameSir T4 Pro Battery Replacement: step 2, image 1 of 1
      • Use your iFixit opening tool to break the seam of the back of your controller.
      • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
      Ask FixBot
    3. GameSir T4 Pro Battery Replacement: step 3, image 1 of 1
      • Using the plastic spudger, wiggle the connection out of place.
      Ask FixBot
    4. GameSir T4 Pro Battery Replacement: step 4, image 1 of 1
      • Apply a slow, but consistent pull to the old 600 maH battery.
      • Attach new battery onto the pad.
      Ask FixBot
3 other people completed this guide.
3 Guide Comments
Battery Model is pl502450 600mah
3.7v
Eugene Eugenio - Reply Share
Where can I buy this battery? Do You have a link to it?
Roberto Barros - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 141
All Time: 5,331
