GameSir Nova Lite Battery Replacement
  1. GameSir Nova Lite Battery Replacement, Battery: step 1, image 1 of 3 GameSir Nova Lite Battery Replacement, Battery: step 1, image 2 of 3 GameSir Nova Lite Battery Replacement, Battery: step 1, image 3 of 3
    • Turn your controller so that the back of the controller is facing you.
    • Remove all six 9 mm-long Phillips #1 screws securing the back plate.
    Ask FixBot
  2. GameSir Nova Lite Battery Replacement: step 2, image 1 of 2 GameSir Nova Lite Battery Replacement: step 2, image 2 of 2
    • Insert an opening tool in the seam between the back and front case.
    • Insert iFixit Opening Picks around the controller to help keep the front and separated.
    • Slowly slide the tool around the controller until the two halves of the controller come apart.
    Ask FixBot
  3. GameSir Nova Lite Battery Replacement: step 3, image 1 of 2 GameSir Nova Lite Battery Replacement: step 3, image 2 of 2
    • Take the back shell off of the controller.
    • Hold the front part of the controller when taking the two halves apart.
    Ask FixBot
  4. GameSir Nova Lite Battery Replacement: step 4, image 1 of 2 GameSir Nova Lite Battery Replacement: step 4, image 2 of 2
    • Lay the controller down so that the motherboard and battery are facing you.
    • Grasp the white battery connector with blunt tweezers, and gently pull it out of its socket.
    Ask FixBot
  5. GameSir Nova Lite Battery Replacement: step 5, image 1 of 2 GameSir Nova Lite Battery Replacement: step 5, image 2 of 2
    • Use tweezers to carefully take the battery off the motherboard.
    • It’s ok if the adhesive strip that is stuck to the battery comes/doesn’t come off.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 97
All Time: 638
