GameSir Nova 2 Lite Button Replacement
    1. GameSir Nova 2 Lite Button Replacement, Battery: step 1, image 1 of 2 GameSir Nova 2 Lite Button Replacement, Battery: step 1, image 2 of 2
      • Before you take your controller apart make sure it is powered off by holding the power button down for 15 seconds until it stops blinking.
      • Use a Phillips #0 screwdriver to remove the four 8.5 mm screws from the bottom of the controller's casing.
      Ask FixBot
    2. GameSir Nova 2 Lite Button Replacement: step 2, image 1 of 3 GameSir Nova 2 Lite Button Replacement: step 2, image 2 of 3 GameSir Nova 2 Lite Button Replacement: step 2, image 3 of 3
      • Insert an opening tool between the two halves to open the controller's casing.
      • You will feel several internal latches called “snap-fit connectors.”
      • Disconnect them by sliding the opening tool along the seam in the casing, applying continuous pressure.
      • Once you find a connector, apply increased pressure until you hear a snapping sound.
      • Repeat this process until all of the connectors are disconnected.
      • Separate the top and bottom of the controller case.
      Ask FixBot
    3. GameSir Nova 2 Lite Button Replacement: step 3, image 1 of 2 GameSir Nova 2 Lite Button Replacement: step 3, image 2 of 2
      • Set aside the bottom half of the shell.
      • Position the controller so that the motherboard is visible.
      • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
      • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
      Ask FixBot
    4. GameSir Nova 2 Lite Button Replacement: step 4, image 1 of 2 GameSir Nova 2 Lite Button Replacement: step 4, image 2 of 2
      • If the battery appears swollen follow this link.
      • The battery is held in place by double-sided adhesive.
      • Use a spudger to loosen the tape securing the battery.
      • Remove the battery from the controller.
      Ask FixBot
    1. GameSir Nova 2 Lite Button Replacement, Rumble Motor: step 5, image 1 of 2 GameSir Nova 2 Lite Button Replacement, Rumble Motor: step 5, image 2 of 2
      • Push on alternating sides of the JST connector to release it from the socket on the circuit board.
      Ask FixBot
    2. GameSir Nova 2 Lite Button Replacement: step 6, image 1 of 1
      • Pull the motor out of its socket.
      • Repeat the steps for the other rumble motor.
      Ask FixBot
    1. GameSir Nova 2 Lite Button Replacement, Buttons: step 7, image 1 of 3 GameSir Nova 2 Lite Button Replacement, Buttons: step 7, image 2 of 3 GameSir Nova 2 Lite Button Replacement, Buttons: step 7, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the six 5.7 mm screws securing the motherboard.
      • Separate the midframe that holds the motherboard from the outer shell.
      Ask FixBot
    2. GameSir Nova 2 Lite Button Replacement: step 8, image 1 of 3 GameSir Nova 2 Lite Button Replacement: step 8, image 2 of 3 GameSir Nova 2 Lite Button Replacement: step 8, image 3 of 3
      • At this point the only thing holding the buttons in place is gravity.
      • Remove the buttons from the top case.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
1 Guide Comment
I .... where to find the ( new stick )for the controller Gamesir ?
Leandro Montiel - Reply Share
Past 24 Hours: 17
Past 7 Days: 49
Past 30 Days: 198
All Time: 1,222
