GameSir Nova 2 Lite Battery Replacement
  1. GameSir Nova 2 Lite Battery Replacement, Battery: step 1, image 1 of 2 GameSir Nova 2 Lite Battery Replacement, Battery: step 1, image 2 of 2
    • Before you take your controller apart make sure it is powered off by holding the power button down for 15 seconds until it stops blinking.
    • Use a Phillips #0 screwdriver to remove the four 8.5 mm screws from the bottom of the controller's casing.
    Ask FixBot
  2. GameSir Nova 2 Lite Battery Replacement: step 2, image 1 of 3 GameSir Nova 2 Lite Battery Replacement: step 2, image 2 of 3 GameSir Nova 2 Lite Battery Replacement: step 2, image 3 of 3
    • Insert an opening tool between the two halves to open the controller's casing.
    • You will feel several internal latches called “snap-fit connectors.”
    • Disconnect them by sliding the opening tool along the seam in the casing, applying continuous pressure.
    • Once you find a connector, apply increased pressure until you hear a snapping sound.
    • Repeat this process until all of the connectors are disconnected.
    • Separate the top and bottom of the controller case.
    Ask FixBot
  3. GameSir Nova 2 Lite Battery Replacement: step 3, image 1 of 2 GameSir Nova 2 Lite Battery Replacement: step 3, image 2 of 2
    • Set aside the bottom half of the shell.
    • Position the controller so that the motherboard is visible.
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    Ask FixBot
  4. GameSir Nova 2 Lite Battery Replacement: step 4, image 1 of 2 GameSir Nova 2 Lite Battery Replacement: step 4, image 2 of 2
    • If the battery appears swollen follow this link.
    • The battery is held in place by double-sided adhesive.
    • Use a spudger to loosen the tape securing the battery.
    • Remove the battery from the controller.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Elias Frank
468 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 174
All Time: 850
