GameSir K1 Kaleid Front Panel Replacement
  1. GameSir K1 Kaleid Front Panel Replacement, Front Panel: step 1, image 1 of 1
    • Remove seven 1 mm screws from the backside of the controller using a TR6 Torx screwdriver.
    • There may be a screw covered under the manufacturer's sticker.
  2. GameSir K1 Kaleid Front Panel Replacement: step 2, image 1 of 3 GameSir K1 Kaleid Front Panel Replacement: step 2, image 2 of 3 GameSir K1 Kaleid Front Panel Replacement: step 2, image 3 of 3
    • Hold the controller between your hands, with the front panel facing down.
    • Lift the back panel.
    • It should come up easily. If met with resistance, check for a missed screw on the back panel.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 43
All Time: 460
