GameSir K1 Kaleid Button Covers Replacement
  1. GameSir K1 Kaleid Button Covers Replacement, Front Panel: step 1, image 1 of 1
    • Remove seven 1 mm screws from the backside of the controller using a TR6 Torx screwdriver.
    • There may be a screw covered under the manufacturer's sticker.
    Ask FixBot
  2. GameSir K1 Kaleid Button Covers Replacement: step 2, image 1 of 3 GameSir K1 Kaleid Button Covers Replacement: step 2, image 2 of 3 GameSir K1 Kaleid Button Covers Replacement: step 2, image 3 of 3
    • Hold the controller between your hands, with the front panel facing down.
    • Lift the back panel.
    • It should come up easily. If met with resistance, check for a missed screw on the back panel.
    Ask FixBot
  3. GameSir K1 Kaleid Button Covers Replacement, Button Covers: step 3, image 1 of 2 GameSir K1 Kaleid Button Covers Replacement, Button Covers: step 3, image 2 of 2
    • Replace needed buttons.
    • Order matters: the buttons have different notches. Going clockwise: Y is at the top, B is to the right, A is bottom, and X is left.
    • A, B, X, Y Buttons.
    • The D-pad
    • The view button
    • The share button
    • The menu button
    • The M button
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 30
All Time: 423
