GameSir G8 Galileo Right Trigger Replacement
  1. GameSir G8 Galileo Right Trigger Replacement, motherboard: step 1, image 1 of 3 GameSir G8 Galileo Right Trigger Replacement, motherboard: step 1, image 2 of 3 GameSir G8 Galileo Right Trigger Replacement, motherboard: step 1, image 3 of 3
    • Use a hair dryer or heat gun on the low setting to gently warm the center grip pad to soften the adhesive underneath.
    • Place the nozzle 2–3 inches above the device and keep moving it in small circles until the surface is warm and the adhesive has loosened.
    • Don't leave the nozzle in one place for two long or you risk damage to the controller.
    Ask FixBot
  2. GameSir G8 Galileo Right Trigger Replacement: step 2, image 1 of 3 GameSir G8 Galileo Right Trigger Replacement: step 2, image 2 of 3 GameSir G8 Galileo Right Trigger Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool into the edge of the center grip pad.
    • Once the edge is free, use your fingers to peel off the grip pad.
    Ask FixBot
  3. GameSir G8 Galileo Right Trigger Replacement: step 3, image 1 of 3 GameSir G8 Galileo Right Trigger Replacement: step 3, image 2 of 3 GameSir G8 Galileo Right Trigger Replacement: step 3, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the three screws from the center front panel.
    Ask FixBot
  4. GameSir G8 Galileo Right Trigger Replacement: step 4, image 1 of 3 GameSir G8 Galileo Right Trigger Replacement: step 4, image 2 of 3 GameSir G8 Galileo Right Trigger Replacement: step 4, image 3 of 3
    • Remove the plastic cover from both sides of the controller with your hand.
    • They’re held in place by magnets and should pop off easily.
    Ask FixBot
  5. GameSir G8 Galileo Right Trigger Replacement: step 5, image 1 of 3 GameSir G8 Galileo Right Trigger Replacement: step 5, image 2 of 3 GameSir G8 Galileo Right Trigger Replacement: step 5, image 3 of 3
    • Remove the two Phillips #0 screws from the right side.
    Ask FixBot
  6. GameSir G8 Galileo Right Trigger Replacement: step 6, image 1 of 3 GameSir G8 Galileo Right Trigger Replacement: step 6, image 2 of 3 GameSir G8 Galileo Right Trigger Replacement: step 6, image 3 of 3
    • Turn the controller around and remove the rear housing.
    • The rear housing covers only the back of the center section and the right grip. The back cover of the left grip remains attached to the controller.
    Ask FixBot
  7. GameSir G8 Galileo Right Trigger Replacement: step 7, image 1 of 3 GameSir G8 Galileo Right Trigger Replacement: step 7, image 2 of 3 GameSir G8 Galileo Right Trigger Replacement: step 7, image 3 of 3
    • Remove nine screws from the motherboard using a Phillips #0 screwdriver.
    • Squeeze the edges of the connector and pull it gently from its socket on the board.
    • Use a spudger or a clean fingernail to flip up the black locking flap—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable from its socket.
    Ask FixBot
  8. GameSir G8 Galileo Right Trigger Replacement: step 8, image 1 of 2 GameSir G8 Galileo Right Trigger Replacement: step 8, image 2 of 2
    • Remove the motherboard.
    Ask FixBot
  9. GameSir G8 Galileo Right Trigger Replacement, Right Trigger: step 9, image 1 of 2 GameSir G8 Galileo Right Trigger Replacement, Right Trigger: step 9, image 2 of 2
    • Use your hands to remove the trigger from the controller.
    Ask FixBot
  10. GameSir G8 Galileo Right Trigger Replacement: step 10, image 1 of 3 GameSir G8 Galileo Right Trigger Replacement: step 10, image 2 of 3 GameSir G8 Galileo Right Trigger Replacement: step 10, image 3 of 3
    • Remove screws from the motherboard.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Fidele Jr
85 Reputation
1 Guide authored
UMass Dartmouth, Team 2-2, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-2, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G2
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 66
All Time: 288
