GameSir G8 Galileo Face Buttons Replacement
  1. GameSir G8 Galileo Face Buttons Replacement, motherboard: step 1, image 1 of 3 GameSir G8 Galileo Face Buttons Replacement, motherboard: step 1, image 2 of 3 GameSir G8 Galileo Face Buttons Replacement, motherboard: step 1, image 3 of 3
    • Use a hair dryer or heat gun on the low setting to gently warm the center grip pad to soften the adhesive underneath.
    • Place the nozzle 2–3 inches above the device and keep moving it in small circles until the surface is warm and the adhesive has loosened.
    • Don't leave the nozzle in one place for two long or you risk damage to the controller.
    Ask FixBot
  2. GameSir G8 Galileo Face Buttons Replacement: step 2, image 1 of 3 GameSir G8 Galileo Face Buttons Replacement: step 2, image 2 of 3 GameSir G8 Galileo Face Buttons Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool into the edge of the center grip pad.
    • Once the edge is free, use your fingers to peel off the grip pad.
    Ask FixBot
  3. GameSir G8 Galileo Face Buttons Replacement: step 3, image 1 of 3 GameSir G8 Galileo Face Buttons Replacement: step 3, image 2 of 3 GameSir G8 Galileo Face Buttons Replacement: step 3, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the three screws from the center front panel.
    Ask FixBot
  4. GameSir G8 Galileo Face Buttons Replacement: step 4, image 1 of 3 GameSir G8 Galileo Face Buttons Replacement: step 4, image 2 of 3 GameSir G8 Galileo Face Buttons Replacement: step 4, image 3 of 3
    • Remove the plastic cover from both sides of the controller with your hand.
    • They’re held in place by magnets and should pop off easily.
    Ask FixBot
  5. GameSir G8 Galileo Face Buttons Replacement: step 5, image 1 of 3 GameSir G8 Galileo Face Buttons Replacement: step 5, image 2 of 3 GameSir G8 Galileo Face Buttons Replacement: step 5, image 3 of 3
    • Remove the two Phillips #0 screws from the right side.
    Ask FixBot
  6. GameSir G8 Galileo Face Buttons Replacement: step 6, image 1 of 3 GameSir G8 Galileo Face Buttons Replacement: step 6, image 2 of 3 GameSir G8 Galileo Face Buttons Replacement: step 6, image 3 of 3
    • Turn the controller around and remove the rear housing.
    • The rear housing covers only the back of the center section and the right grip. The back cover of the left grip remains attached to the controller.
    Ask FixBot
  7. GameSir G8 Galileo Face Buttons Replacement: step 7, image 1 of 3 GameSir G8 Galileo Face Buttons Replacement: step 7, image 2 of 3 GameSir G8 Galileo Face Buttons Replacement: step 7, image 3 of 3
    • Remove nine screws from the motherboard using a Phillips #0 screwdriver.
    • Squeeze the edges of the connector and pull it gently from its socket on the board.
    • Use a spudger or a clean fingernail to flip up the black locking flap—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable from its socket.
    Ask FixBot
  8. GameSir G8 Galileo Face Buttons Replacement: step 8, image 1 of 2 GameSir G8 Galileo Face Buttons Replacement: step 8, image 2 of 2
    • Remove the motherboard.
    Ask FixBot
  9. GameSir G8 Galileo Face Buttons Replacement, Face Buttons: step 9, image 1 of 3 GameSir G8 Galileo Face Buttons Replacement, Face Buttons: step 9, image 2 of 3 GameSir G8 Galileo Face Buttons Replacement, Face Buttons: step 9, image 3 of 3
    • Once the motherboard is removed from the area, you will have access to the face or action buttons.
    • Pull out the A, B, X, and Y buttons.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Cayden Blaschik
195 Reputation
2 Guides authored
UMass Dartmouth, Team 2-2, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-2, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G2
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 35
Past 30 Days: 166
All Time: 892
