GameSir G7 SE Motherboard Replacement
  1. GameSir G7 SE Motherboard Replacement, Interior face plate: step 1, image 1 of 1
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
    Ask FixBot
  2. GameSir G7 SE Motherboard Replacement: step 2, image 1 of 2 GameSir G7 SE Motherboard Replacement: step 2, image 2 of 2
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
    Ask FixBot
  3. GameSir G7 SE Motherboard Replacement: step 3, image 1 of 2 GameSir G7 SE Motherboard Replacement: step 3, image 2 of 2
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
    Ask FixBot
  4. GameSir G7 SE Motherboard Replacement, Motherboard: step 4, image 1 of 1
    • Use the Phillips #0 screwdriver bit to remove the four 9 mm screws holding the motherboard in place.
    Ask FixBot
  5. GameSir G7 SE Motherboard Replacement: step 5, image 1 of 1
    • Pull straight up on the board to remove the motherboard and connecting components
    • Be careful to not dislodge the back buttons from the back plate housing
    Ask FixBot
2 other people completed this guide.
1 Guide Comment
Hello,where did you find or buy a new motherboard for this?
DavidofSlim7 - Reply Share
Past 24 Hours: 8
Past 7 Days: 34
Past 30 Days: 142
All Time: 2,961
