Up to 20% off select tools
GameSir G7 SE Joystick Module Replacement
Views: 16K
View statistics:
Past 24 Hours:
22
Past 7 Days:
189
Past 30 Days:
733
All Time:
16,481
Comments: 6
2 comments on steps, 4 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Addressing joystick wear or malfunction, this guide assists GameSir G7 SE owners in replacing their joystick modules. Common symptoms that necessitate this repair include drifting, sticking, or unresponsiveness, affecting game control accuracy.
Disconnect the controller from all power sources before beginning the repair to ensure safety. Troubleshooting page sections such as “Joystick Drift” or “Sticky Joystick” might offer additional insights before you start.
    1. GameSir G7 SE Joystick Module Replacement, Interior face plate: step 1, image 1 of 1
      • Remove the faceplate by prying upwards with a plastic opening tool.
      • This faceplate is magnetic and will be easy to come off.
      Ask FixBot
    2. GameSir G7 SE Joystick Module Replacement: step 2, image 1 of 2 GameSir G7 SE Joystick Module Replacement: step 2, image 2 of 2
      • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
      Ask FixBot
    3. GameSir G7 SE Joystick Module Replacement: step 3, image 1 of 2 GameSir G7 SE Joystick Module Replacement: step 3, image 2 of 2
      • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
      • Make sure to hold the controller upside down; otherwise the buttons will fall out.
      Ask FixBot
    1. GameSir G7 SE Joystick Module Replacement, Joystick Module: step 4, image 1 of 1
      • Remove the plastic joystick that is covering the joystick module by pulling up on from the gray grip.
      Ask FixBot
    2. GameSir G7 SE Joystick Module Replacement: step 5, image 1 of 1
      • To gain access to the joystick module, you will need to gently bend the metal retention clips that hold the module in place.
      • Use a plastic spudger to gently bend the retention clips back.
      Ask FixBot
    3. GameSir G7 SE Joystick Module Replacement: step 6, image 1 of 1
      • Pull directly up on the joystick module to remove it from the motherboard.
      • Make sure to hold the joystick module from the red portion to prevent it from falling apart.
      Ask FixBot
8 other people completed this guide.
Author
with
AJ Saks
312 Reputation
1 Guide authored
4 Guide Comments
Where to get the replacement parts?
Isaiah Hackworth - Reply Share
Where do you get the replacement parts from?
michaeljhs - Reply Share
Guida inutile senza ricambio
Matteo Andreani - Reply Share
Controller joystick fell apart on me. I used the video explaining the TMR sticks from gamesir to reassemble. Found this to find out I could fix it. Thank you a ton I fix it.
Devoid - Reply Share
Past 24 Hours: 22
Past 7 Days: 189
Past 30 Days: 733
All Time: 16,481
