GameSir G7 SE Button Gaskets Replacement
    1. GameSir G7 SE Button Gaskets Replacement, Interior face plate: step 1, image 1 of 1
      • Remove the faceplate by prying upwards with a plastic opening tool.
      • This faceplate is magnetic and will be easy to come off.
      Ask FixBot
    2. GameSir G7 SE Button Gaskets Replacement: step 2, image 1 of 2 GameSir G7 SE Button Gaskets Replacement: step 2, image 2 of 2
      • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
      Ask FixBot
    3. GameSir G7 SE Button Gaskets Replacement: step 3, image 1 of 2 GameSir G7 SE Button Gaskets Replacement: step 3, image 2 of 2
      • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
      • Make sure to hold the controller upside down; otherwise the buttons will fall out.
      Ask FixBot
    1. GameSir G7 SE Button Gaskets Replacement, Button Gaskets: step 4, image 1 of 1
      • Pull up on the conductive rubber button gaskets to remove them.
      • Additionally, clean contacts with 91% isopropyl alcohol if needed.
      Ask FixBot
    2. GameSir G7 SE Button Gaskets Replacement: step 5, image 1 of 2 GameSir G7 SE Button Gaskets Replacement: step 5, image 2 of 2
      • Make sure that the longer prongs on the button shroud/guide are facing you when reassembling.
      Ask FixBot
Nicolai
85 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 50
Past 30 Days: 269
All Time: 6,855
