GameSir G4 Pro Thumbstick Caps Replacement
    1. GameSir G4 Pro Thumbstick Caps Replacement, Battery: step 1, image 1 of 2 GameSir G4 Pro Thumbstick Caps Replacement, Battery: step 1, image 2 of 2
      • Remove the dongle from the controller.
      Ask FixBot
    2. GameSir G4 Pro Thumbstick Caps Replacement: step 2, image 1 of 2 GameSir G4 Pro Thumbstick Caps Replacement: step 2, image 2 of 2
      • Use a metal spudger to remove the rubber screw caps on the rear case.
      Ask FixBot
    3. GameSir G4 Pro Thumbstick Caps Replacement: step 3, image 1 of 3 GameSir G4 Pro Thumbstick Caps Replacement: step 3, image 2 of 3 GameSir G4 Pro Thumbstick Caps Replacement: step 3, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 9.5 mm screws on the rear case.
      Ask FixBot
    4. GameSir G4 Pro Thumbstick Caps Replacement: step 4, image 1 of 3 GameSir G4 Pro Thumbstick Caps Replacement: step 4, image 2 of 3 GameSir G4 Pro Thumbstick Caps Replacement: step 4, image 3 of 3
      • Use a metal spudger to pry off the two controller grips.
      Ask FixBot
    5. GameSir G4 Pro Thumbstick Caps Replacement: step 5, image 1 of 3 GameSir G4 Pro Thumbstick Caps Replacement: step 5, image 2 of 3 GameSir G4 Pro Thumbstick Caps Replacement: step 5, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the 9.5 mm screws on the top of each handle.
      • Use a Phillips #0 screwdriver to remove the 9.5 mm screws on the bottom of each handle.
      Ask FixBot
    6. GameSir G4 Pro Thumbstick Caps Replacement: step 6, image 1 of 1
      • Optional: Wrap an antistatic wrist strap around your wrist and attach the clamp to a grounded metal surface.
      Ask FixBot
    7. GameSir G4 Pro Thumbstick Caps Replacement: step 7, image 1 of 2 GameSir G4 Pro Thumbstick Caps Replacement: step 7, image 2 of 2
      • Remove the back panel.
      Ask FixBot
    8. GameSir G4 Pro Thumbstick Caps Replacement: step 8, image 1 of 2 GameSir G4 Pro Thumbstick Caps Replacement: step 8, image 2 of 2
      • Use tweezers or your fingernails to walk the white battery connector out of its motherboard socket.
      Ask FixBot
    9. GameSir G4 Pro Thumbstick Caps Replacement: step 9, image 1 of 2 GameSir G4 Pro Thumbstick Caps Replacement: step 9, image 2 of 2
      • Lift and remove the battery.
      Ask FixBot
    1. GameSir G4 Pro Thumbstick Caps Replacement, Thumbstick Caps: step 10, image 1 of 2 GameSir G4 Pro Thumbstick Caps Replacement, Thumbstick Caps: step 10, image 2 of 2
      • Carefully pull out the motherboard with your hands from the faceplate.
      Ask FixBot
    2. GameSir G4 Pro Thumbstick Caps Replacement: step 11, image 1 of 2 GameSir G4 Pro Thumbstick Caps Replacement: step 11, image 2 of 2
      • Gently pull off the thumbsticks caps.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 49
All Time: 133
