GameSir Cyclone 2 Top Cover Replacement
  1. GameSir Cyclone 2 Top Cover Replacement, Top Cover: step 1, image 1 of 3 GameSir Cyclone 2 Top Cover Replacement, Top Cover: step 1, image 2 of 3 GameSir Cyclone 2 Top Cover Replacement, Top Cover: step 1, image 3 of 3
    • Use a T6 Torx to remove seven screws from the bottom of the controller.
    • The last screw is under the sticker. Lift the sticker with tweezers, then then remove the final screw.
  2. GameSir Cyclone 2 Top Cover Replacement: step 2, image 1 of 1
    • The two larger screws belong on the top two sockets of the controller
  3. GameSir Cyclone 2 Top Cover Replacement: step 3, image 1 of 1
    • The remaining five sockets in these locations
  4. GameSir Cyclone 2 Top Cover Replacement: step 4, image 1 of 2 GameSir Cyclone 2 Top Cover Replacement: step 4, image 2 of 2
    • The front plate should pop with minimal force with the D-Pad and action buttons becoming loose as well.
Ross Debortoli
325 Reputation
3 Guides authored
UMass Dartmouth, Team 2-6, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-6, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G6
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 47
All Time: 147
