Up to 20% off select tools
GameSir Cyclone 2 LED Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
102
All Time:
611
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 - 50 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Follow the instructions in this guide to replace the RGB lights in your GameSir Cyclone 2 controller.
    1. GameSir Cyclone 2 LED Replacement, Face Plate: step 1, image 1 of 3 GameSir Cyclone 2 LED Replacement, Face Plate: step 1, image 2 of 3 GameSir Cyclone 2 LED Replacement, Face Plate: step 1, image 3 of 3
      • Flip the controller around so the back part is facing you.
      • Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
      • One of the screws is hidden under the sticker. Use a pair of tweezers to lift the sticker and reveal the screw.
      Ask FixBot
    2. GameSir Cyclone 2 LED Replacement: step 2, image 1 of 1
      • The screws holding the face plate are of two different lengths:
      • The two longer screws belong to the two top screw sockets on the controller.
      • The five shorter screws belong in the five bottom screw sockets, two per handle, and on in the center of on the controller.
      Ask FixBot
    3. GameSir Cyclone 2 LED Replacement: step 3, image 1 of 2 GameSir Cyclone 2 LED Replacement: step 3, image 2 of 2
      • Face the controller toward you.
      • Gently lift the face plate off the controller.
      • The d-pad and action buttons will become loose once the face plate is lifted.
      Ask FixBot
    1. GameSir Cyclone 2 LED Replacement, Joystick Covers: step 4, image 1 of 3 GameSir Cyclone 2 LED Replacement, Joystick Covers: step 4, image 2 of 3 GameSir Cyclone 2 LED Replacement, Joystick Covers: step 4, image 3 of 3
      • Pull both joystick covers straight up to remove them from the controller.
      Ask FixBot
    1. GameSir Cyclone 2 LED Replacement, Left and Right Bumpers and Triggers: step 5, image 1 of 1
      • Note the bumpers and triggers on the controller.
      Ask FixBot
    2. GameSir Cyclone 2 LED Replacement: step 6, image 1 of 1
      • Use a Phillips #00 screwdriver to remove two screws on either side of the power button.
      • Remove the assembly that includes the power button and the top bumper buttons.
      Ask FixBot
    3. GameSir Cyclone 2 LED Replacement: step 7, image 1 of 1
      • Remove the bumpers and triggers from the controller.
      Ask FixBot
    1. GameSir Cyclone 2 LED Replacement, LED: step 8, image 1 of 1
      • Locate the two black boxes towards the bottom of the controller.
      • Remove these two boxes by pulling them away from the controller. They should snap right off.
      Ask FixBot
    2. GameSir Cyclone 2 LED Replacement: step 9, image 1 of 1
      • Locate the LED diffusers on either side of the controller face. They are clear, cylindrical strips that help spread light from the LED beneath the black boxes removed in the previous step.
      • Lift the upper ends of each LED diffuser and remove them.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Ross Debortoli
334 Reputation
3 Guides authored
UMass Dartmouth, Team 2-6, Bowman Fall 2025 Member of UMass Dartmouth, Team 2-6, Bowman Fall 2025
UMASSD-BOWMAN-F25S2G6
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 102
All Time: 611
