Game Boy Pocket Motherboard Replacement
    1. Game Boy Pocket Motherboard Replacement, Back Cover: step 1, image 1 of 3 Game Boy Pocket Motherboard Replacement, Back Cover: step 1, image 2 of 3 Game Boy Pocket Motherboard Replacement, Back Cover: step 1, image 3 of 3
      • Place the Game Boy Pocket face-down on a clean, flat surface.
      • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
      • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
      Ask FixBot
    2. Game Boy Pocket Motherboard Replacement: step 2, image 1 of 3 Game Boy Pocket Motherboard Replacement: step 2, image 2 of 3 Game Boy Pocket Motherboard Replacement: step 2, image 3 of 3
      • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
      • Set the back cover aside. You will need it to reassemble the device.
      Ask FixBot
    1. Game Boy Pocket Motherboard Replacement, Motherboard: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
      Ask FixBot
    2. Game Boy Pocket Motherboard Replacement: step 4, image 1 of 3 Game Boy Pocket Motherboard Replacement: step 4, image 2 of 3 Game Boy Pocket Motherboard Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
      • Make sure you apply pressure on both sides of the clip to loosen it.
      Ask FixBot
    3. Game Boy Pocket Motherboard Replacement: step 5, image 1 of 2 Game Boy Pocket Motherboard Replacement: step 5, image 2 of 2
      • Use a plastic opening tool to dislodge the ribbon cable.
      • Be gentle to prevent tearing the ribbon.
      Ask FixBot
    4. Game Boy Pocket Motherboard Replacement: step 6, image 1 of 2 Game Boy Pocket Motherboard Replacement: step 6, image 2 of 2
      • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
      Ask FixBot
7 other people completed this guide.
Adriana Rahrig
1,688 Reputation
5 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2014 Member of USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 87
All Time: 7,576
