Up to 20% off select tools
Game Boy Pocket LCD Screen Replacement
Views: 38K
View statistics:
Past 24 Hours:
8
Past 7 Days:
108
Past 30 Days:
576
All Time:
37,990
Comments: 6
3 comments on steps, 3 guide comments.
Go to guide comments
Completed: 21
21 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
If the LCD screen in your Game Boy Pocket is damaged or simply not working and needs replaced, this guide will help you replace and repair your screen. No special skills are required for this replacement. All you need is a small Phillips screwdriver and a plastic opening tool. There is nothing unusual about this repair and it is straightforward.
    1. Game Boy Pocket LCD Screen Replacement, Remove the external screws: step 1, image 1 of 3 Game Boy Pocket LCD Screen Replacement, Remove the external screws: step 1, image 2 of 3 Game Boy Pocket LCD Screen Replacement, Remove the external screws: step 1, image 3 of 3
      • Place the Game Boy Pocket face-down on a clean, flat surface.
      • Remove batteries from battery compartment.
      • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
      • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
      Ask FixBot
    2. Game Boy Pocket LCD Screen Replacement, Open the device: step 2, image 1 of 3 Game Boy Pocket LCD Screen Replacement, Open the device: step 2, image 2 of 3 Game Boy Pocket LCD Screen Replacement, Open the device: step 2, image 3 of 3
      • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
      • Set the back cover aside. You will need it to reassemble the device.
      Ask FixBot
    3. Game Boy Pocket LCD Screen Replacement, Remove the motherboard screws: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver and turn counterclockwise to remove the three screws on the motherboard.
      Ask FixBot
    4. Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: step 4, image 1 of 3 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: step 4, image 2 of 3 Game Boy Pocket LCD Screen Replacement, Remove the clip securing the ribbon cable: step 4, image 3 of 3
      • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
      • Make sure you apply pressure on both sides of the clip to loosen it.
      Ask FixBot
    5. Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: step 5, image 1 of 2 Game Boy Pocket LCD Screen Replacement, Dislodge the ribbon cable: step 5, image 2 of 2
      • Use a plastic opening tool to dislodge the ribbon cable.
      • Be gentle to prevent tearing the ribbon.
      Ask FixBot
    6. Game Boy Pocket LCD Screen Replacement, Remove the motherboard: step 6, image 1 of 3 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: step 6, image 2 of 3 Game Boy Pocket LCD Screen Replacement, Remove the motherboard: step 6, image 3 of 3
      • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
      • Set the motherboard aside. You will need it to reassemble the device.
      Ask FixBot
    7. Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: step 7, image 1 of 3 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: step 7, image 2 of 3 Game Boy Pocket LCD Screen Replacement, Remove the LCD screen: step 7, image 3 of 3
      • Use a plastic opening tool to lift the LCD screen away from the front cover.
      • Use your fingers to remove the LCD screen.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
21 other people completed this guide.
Author
with
Adriana Rahrig
1,708 Reputation
5 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2014 Member of USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Members
60 Guides authored
3 Guide Comments
please can anyone give me a website that sells replacemtn screens for the Gameboy pocket?
help please - Reply Share
There's no website that sells replacement screens the only way to get one is to order another Gameboy off of eBay and take out the screen
Isaac fraser - Reply Share
I get mine from Handheld Legend. They have all the Gameboy parts you could ever want.
Chris Pavlik - Reply Share
Past 24 Hours: 8
Past 7 Days: 108
Past 30 Days: 576
All Time: 37,990
