Up to 20% off select tools
Game Boy Pocket Buttons Replacement
Views: 6.5K
View statistics:
Past 24 Hours:
12
Past 7 Days:
39
Past 30 Days:
152
All Time:
6,470
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Parts
Tools
Introduction
Go to step 1 ↓
If you need to replace the face buttons on a Game Boy Pocket (model MGB-001) due to worn-out buttons or to customize your console, use this guide to remove and replace the buttons. No prior experience or soldering is required.
The Game Boy Pocket has five buttons located on the front of the device:
  • Directional Pad (D-Pad)
  • A
  • B
  • Start
  • Select
Before beginning, ensure that the console is powered off by moving the power switch located on the top left corner to the left position. It is recommended that you remove the two AAA batteries located on the lower backside of the console as well as any game cartridges from the slot on the top of the console.
    1. Game Boy Pocket Buttons Replacement, Buttons: step 1, image 1 of 3 Game Boy Pocket Buttons Replacement, Buttons: step 1, image 2 of 3 Game Boy Pocket Buttons Replacement, Buttons: step 1, image 3 of 3
      • Place the Game Boy Pocket face-down on a clean, flat surface.
      • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the four external screws.
      • Use a Y1 tri-wing screwdriver and turn counterclockwise to remove the two screws inside the battery compartment.
      Ask FixBot
    2. Game Boy Pocket Buttons Replacement: step 2, image 1 of 3 Game Boy Pocket Buttons Replacement: step 2, image 2 of 3 Game Boy Pocket Buttons Replacement: step 2, image 3 of 3
      • Place your hands on the front and back covers of the Game Boy Pocket, and carefully separate the device.
      • Set the back cover aside. You will need it to reassemble the device.
      Ask FixBot
    3. Game Boy Pocket Buttons Replacement: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the three screws from the motherboard.
      Ask FixBot
    4. Game Boy Pocket Buttons Replacement: step 4, image 1 of 3 Game Boy Pocket Buttons Replacement: step 4, image 2 of 3 Game Boy Pocket Buttons Replacement: step 4, image 3 of 3
      • Use a plastic opening tool to dislodge and remove the clip securing the ribbon cable.
      • Make sure you apply pressure on both sides of the clip to loosen it.
      Ask FixBot
    5. Game Boy Pocket Buttons Replacement: step 5, image 1 of 2 Game Boy Pocket Buttons Replacement: step 5, image 2 of 2
      • Use a plastic opening tool to dislodge the ribbon cable.
      • Be gentle to prevent tearing the ribbon.
      Ask FixBot
    6. Game Boy Pocket Buttons Replacement: step 6, image 1 of 3 Game Boy Pocket Buttons Replacement: step 6, image 2 of 3 Game Boy Pocket Buttons Replacement: step 6, image 3 of 3
      • Grab the black piece protruding from the motherboard, and lift up to remove the motherboard.
      • Set the motherboard aside. You will need it to reassemble the device.
      Ask FixBot
    7. Game Boy Pocket Buttons Replacement: step 7, image 1 of 3 Game Boy Pocket Buttons Replacement: step 7, image 2 of 3 Game Boy Pocket Buttons Replacement: step 7, image 3 of 3
      • Use your fingers to remove the three silicone button covers.
      • Use a plastic opening tool to remove the buttons.
      Ask FixBot
3 other people completed this guide.
Author
with
Adriana Rahrig
1,708 Reputation
5 Guides authored
USF Tampa, Team 1-1, Leahy Fall 2014 Member of USF Tampa, Team 1-1, Leahy Fall 2014
USFT-LEAHY-F14S1G1
4 Members
60 Guides authored
1 Guide Comment
where can you just buy the a and b buttons (if possible)
Eian Anderson - Reply Share
Past 24 Hours: 12
Past 7 Days: 39
Past 30 Days: 152
All Time: 6,470
