Up to 20% off select tools
Game Boy Micro LCD Screen Replacement
Views: 30K
View statistics:
Past 24 Hours:
7
Past 7 Days:
45
Past 30 Days:
240
All Time:
30,394
Comments: 9
9 comments on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Difficult
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
In this guide, we'll show you how to change the LCD Screen.
    1. Game Boy Micro LCD Screen Replacement, Remove the Cover: step 1, image 1 of 2 Game Boy Micro LCD Screen Replacement, Remove the Cover: step 1, image 2 of 2
      • Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
      • Once the screw has been loosened, lift the cover off the back of the device.
      Ask FixBot
    1. Game Boy Micro LCD Screen Replacement, Faceplate: step 2, image 1 of 2 Game Boy Micro LCD Screen Replacement, Faceplate: step 2, image 2 of 2
      • Locate the two circular holes on the side of the Game Boy nearest to the directional pad.
      Ask FixBot
    2. Game Boy Micro LCD Screen Replacement: step 3, image 1 of 3 Game Boy Micro LCD Screen Replacement: step 3, image 2 of 3 Game Boy Micro LCD Screen Replacement: step 3, image 3 of 3
      • Straighten the end of a paper clip and push it into each of the circular holes.
      • You may hear a faint click afterwards.
      • Use the paper clip to lever the faceplate off from the unit.
      Ask FixBot
    1. Game Boy Micro LCD Screen Replacement, Unscrew the Outer Cover: step 4, image 1 of 2 Game Boy Micro LCD Screen Replacement, Unscrew the Outer Cover: step 4, image 2 of 2
      • Remove the two tri-wing screws on the top of the Game Boy and the two screws next to the volume/contrast switch.
      Ask FixBot
    2. Game Boy Micro LCD Screen Replacement: step 5, image 1 of 3 Game Boy Micro LCD Screen Replacement: step 5, image 2 of 3 Game Boy Micro LCD Screen Replacement: step 5, image 3 of 3
      • Remove the three Phillips #00 screws.
      • Remove the two tri-wing screws.
      Ask FixBot
    3. Game Boy Micro LCD Screen Replacement: step 6, image 1 of 3 Game Boy Micro LCD Screen Replacement: step 6, image 2 of 3 Game Boy Micro LCD Screen Replacement: step 6, image 3 of 3
      • Lift the back cover off of the Game Boy.
      Ask FixBot
    4. Game Boy Micro LCD Screen Replacement: step 7, image 1 of 3 Game Boy Micro LCD Screen Replacement: step 7, image 2 of 3 Game Boy Micro LCD Screen Replacement: step 7, image 3 of 3
      • Remove the two Phillips #00 screws from the plastic frame.
      • As you are pulling off the plastic frame, the shoulder buttons and the volume switch may fall out of the device.
      • Underneath each shoulder button is a small spring. Do not lose them.
      Ask FixBot
    5. Game Boy Micro LCD Screen Replacement: step 8, image 1 of 2 Game Boy Micro LCD Screen Replacement: step 8, image 2 of 2
      • With a spudger, depress the small clip on the lower right corner of the plastic guard.
      • Grab the edges of the plastic frame and lift the frame off the motherboard.
      Ask FixBot
    6. Game Boy Micro LCD Screen Replacement: step 9, image 1 of 1
      • Remove the two gold Phillips #00 screws from the motherboard.
      Ask FixBot
    7. Game Boy Micro LCD Screen Replacement: step 10, image 1 of 2 Game Boy Micro LCD Screen Replacement: step 10, image 2 of 2
      • With one hand, gently slide the top left end of the motherboard up and out of the front case.
      • With your other hand, pull out the EMI shield until the tab comes out of the front case.
      • Once the tab is pulled out from the bottom, slide the EMI shield down and out of the device.
      Ask FixBot
    8. Game Boy Micro LCD Screen Replacement: step 11, image 1 of 3 Game Boy Micro LCD Screen Replacement: step 11, image 2 of 3 Game Boy Micro LCD Screen Replacement: step 11, image 3 of 3
      • The entire motherboard is now accessible.
      • Take extreme care when working with the motherboard to avoid damaging the device and its components.
      • A small ribbon cable connects the start and select buttons to the motherboard. It can rip very easily, so do not pull on it.
      • Lift the motherboard and the front plastic cover assembly off of the front case.
      • Once the front case is removed, the plastic on/off switch will fall out of place.
      Ask FixBot
    9. Game Boy Micro LCD Screen Replacement: step 12, image 1 of 3 Game Boy Micro LCD Screen Replacement: step 12, image 2 of 3 Game Boy Micro LCD Screen Replacement: step 12, image 3 of 3
      Tool used on this step:
      Buy
      • When you remove the motherboard from the front case, the start and select buttons may fall out.
      • If the buttons do not fall out, remove them with a pair of tweezers.
      Ask FixBot
    10. Game Boy Micro LCD Screen Replacement: step 13, image 1 of 3 Game Boy Micro LCD Screen Replacement: step 13, image 2 of 3 Game Boy Micro LCD Screen Replacement: step 13, image 3 of 3
      • Without the front case, you will be left with the motherboard and the plastic mount. The LCD screen is attached to the motherboard by a ribbon and can fall off the plastic mount.
      • Using metal tweezers, grab the start/select board and slide it out gently.
      Ask FixBot
    11. Game Boy Micro LCD Screen Replacement: step 14, image 1 of 2 Game Boy Micro LCD Screen Replacement: step 14, image 2 of 2
      • Lift the entire motherboard assembly off the plastic guard.
      • Take caution not to damage any of the gold ribbon cables on the motherboard.
      • The LCD screen is the only thing connecting the motherboard and plastic guard.
      Ask FixBot
    12. Game Boy Micro LCD Screen Replacement: step 15, image 1 of 2 Game Boy Micro LCD Screen Replacement: step 15, image 2 of 2
      • To remove the LCD screen, carefully angle it until it is diagonal to the square hole in the plastic guard and slide it out.
      • It is now possible to remove the entire motherboard assembly from the plastic guard.
      Ask FixBot
    13. Game Boy Micro LCD Screen Replacement: step 16, image 1 of 3 Game Boy Micro LCD Screen Replacement: step 16, image 2 of 3 Game Boy Micro LCD Screen Replacement: step 16, image 3 of 3
      • On the plastic guard, there are two rubber pads that cover the buttons. Remove them.
      • These pads rest on the motherboard and sometimes stick to it. If they do, peel them off.
      • With the rubber pads off, you may use your fingers to remove the buttons to clean or replace them.
      • When returning the buttons to the guard, they have to be put back in exactly the way they were pulled out.
      Ask FixBot
    1. Game Boy Micro LCD Screen Replacement, Motherboard: step 17, image 1 of 3 Game Boy Micro LCD Screen Replacement, Motherboard: step 17, image 2 of 3 Game Boy Micro LCD Screen Replacement, Motherboard: step 17, image 3 of 3
      • The LCD screen is connected to the motherboard by two ribbon cables.
      • Use a plastic spudger to disconnect the LCD's ZIF connector.
      Ask FixBot
    2. Game Boy Micro LCD Screen Replacement: step 18, image 1 of 3 Game Boy Micro LCD Screen Replacement: step 18, image 2 of 3 Game Boy Micro LCD Screen Replacement: step 18, image 3 of 3
      • Use the tip of the spudger to lift the small, black tab holding the thin ribbon.
      • With both tabs lifted, pull the ribbons off the motherboard and remove the LCD screen.
      Ask FixBot
    1. Game Boy Micro LCD Screen Replacement, LCD Screen: step 19, image 1 of 2 Game Boy Micro LCD Screen Replacement, LCD Screen: step 19, image 2 of 2
      • The LCD can now be cleaned or replaced.
      Ask FixBot
7 other people completed this guide.
Author
with
Brendan Kelly
278 Reputation
2 Guides authored
Cal Poly, Team 8-46, Regan Winter 2010 Member of Cal Poly, Team 8-46, Regan Winter 2010
CPSU-REGAN-W10S8G46
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 45
Past 30 Days: 240
All Time: 30,394
