Up to 20% off select tools
Game Boy Micro Buttons Replacement
Views: 32K
View statistics:
Past 24 Hours:
11
Past 7 Days:
47
Past 30 Days:
252
All Time:
32,288
Comments: 14
9 comments on steps, 5 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Tools
Introduction
Go to step 1 ↓
Use the following guide to replace buttons in the device.
    1. Game Boy Micro Buttons Replacement, Remove the Cover: step 1, image 1 of 2 Game Boy Micro Buttons Replacement, Remove the Cover: step 1, image 2 of 2
      • Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
      • Once the screw has been loosened, lift the cover off the back of the device.
      Ask FixBot
    1. Game Boy Micro Buttons Replacement, Faceplate: step 2, image 1 of 2 Game Boy Micro Buttons Replacement, Faceplate: step 2, image 2 of 2
      • Locate the two circular holes on the side of the Game Boy nearest to the directional pad.
      Ask FixBot
    2. Game Boy Micro Buttons Replacement: step 3, image 1 of 3 Game Boy Micro Buttons Replacement: step 3, image 2 of 3 Game Boy Micro Buttons Replacement: step 3, image 3 of 3
      • Straighten the end of a paper clip and push it into each of the circular holes.
      • You may hear a faint click afterwards.
      • Use the paper clip to lever the faceplate off from the unit.
      Ask FixBot
    1. Game Boy Micro Buttons Replacement, Unscrew the Outer Cover: step 4, image 1 of 2 Game Boy Micro Buttons Replacement, Unscrew the Outer Cover: step 4, image 2 of 2
      • Remove the two tri-wing screws on the top of the Game Boy and the two screws next to the volume/contrast switch.
      Ask FixBot
    2. Game Boy Micro Buttons Replacement: step 5, image 1 of 3 Game Boy Micro Buttons Replacement: step 5, image 2 of 3 Game Boy Micro Buttons Replacement: step 5, image 3 of 3
      • Remove the three Phillips #00 screws.
      • Remove the two tri-wing screws.
      Ask FixBot
    3. Game Boy Micro Buttons Replacement: step 6, image 1 of 3 Game Boy Micro Buttons Replacement: step 6, image 2 of 3 Game Boy Micro Buttons Replacement: step 6, image 3 of 3
      • Lift the back cover off of the Game Boy.
      Ask FixBot
    4. Game Boy Micro Buttons Replacement: step 7, image 1 of 3 Game Boy Micro Buttons Replacement: step 7, image 2 of 3 Game Boy Micro Buttons Replacement: step 7, image 3 of 3
      • Remove the two Phillips #00 screws from the plastic frame.
      • As you are pulling off the plastic frame, the shoulder buttons and the volume switch may fall out of the device.
      • Underneath each shoulder button is a small spring. Do not lose them.
      Ask FixBot
    5. Game Boy Micro Buttons Replacement: step 8, image 1 of 2 Game Boy Micro Buttons Replacement: step 8, image 2 of 2
      • With a spudger, depress the small clip on the lower right corner of the plastic guard.
      • Grab the edges of the plastic frame and lift the frame off the motherboard.
      Ask FixBot
    6. Game Boy Micro Buttons Replacement: step 9, image 1 of 1
      • Remove the two gold Phillips #00 screws from the motherboard.
      Ask FixBot
    7. Game Boy Micro Buttons Replacement: step 10, image 1 of 2 Game Boy Micro Buttons Replacement: step 10, image 2 of 2
      • With one hand, gently slide the top left end of the motherboard up and out of the front case.
      • With your other hand, pull out the EMI shield until the tab comes out of the front case.
      • Once the tab is pulled out from the bottom, slide the EMI shield down and out of the device.
      Ask FixBot
    8. Game Boy Micro Buttons Replacement: step 11, image 1 of 3 Game Boy Micro Buttons Replacement: step 11, image 2 of 3 Game Boy Micro Buttons Replacement: step 11, image 3 of 3
      • The entire motherboard is now accessible.
      • Take extreme care when working with the motherboard to avoid damaging the device and its components.
      • A small ribbon cable connects the start and select buttons to the motherboard. It can rip very easily, so do not pull on it.
      • Lift the motherboard and the front plastic cover assembly off of the front case.
      • Once the front case is removed, the plastic on/off switch will fall out of place.
      Ask FixBot
    9. Game Boy Micro Buttons Replacement: step 12, image 1 of 3 Game Boy Micro Buttons Replacement: step 12, image 2 of 3 Game Boy Micro Buttons Replacement: step 12, image 3 of 3
      Tool used on this step:
      Buy
      • When you remove the motherboard from the front case, the start and select buttons may fall out.
      • If the buttons do not fall out, remove them with a pair of tweezers.
      Ask FixBot
    10. Game Boy Micro Buttons Replacement: step 13, image 1 of 3 Game Boy Micro Buttons Replacement: step 13, image 2 of 3 Game Boy Micro Buttons Replacement: step 13, image 3 of 3
      • Without the front case, you will be left with the motherboard and the plastic mount. The LCD screen is attached to the motherboard by a ribbon and can fall off the plastic mount.
      • Using metal tweezers, grab the start/select board and slide it out gently.
      Ask FixBot
    11. Game Boy Micro Buttons Replacement: step 14, image 1 of 2 Game Boy Micro Buttons Replacement: step 14, image 2 of 2
      • Lift the entire motherboard assembly off the plastic guard.
      • Take caution not to damage any of the gold ribbon cables on the motherboard.
      • The LCD screen is the only thing connecting the motherboard and plastic guard.
      Ask FixBot
    12. Game Boy Micro Buttons Replacement: step 15, image 1 of 2 Game Boy Micro Buttons Replacement: step 15, image 2 of 2
      • To remove the LCD screen, carefully angle it until it is diagonal to the square hole in the plastic guard and slide it out.
      • It is now possible to remove the entire motherboard assembly from the plastic guard.
      Ask FixBot
    13. Game Boy Micro Buttons Replacement: step 16, image 1 of 3 Game Boy Micro Buttons Replacement: step 16, image 2 of 3 Game Boy Micro Buttons Replacement: step 16, image 3 of 3
      • On the plastic guard, there are two rubber pads that cover the buttons. Remove them.
      • These pads rest on the motherboard and sometimes stick to it. If they do, peel them off.
      • With the rubber pads off, you may use your fingers to remove the buttons to clean or replace them.
      • When returning the buttons to the guard, they have to be put back in exactly the way they were pulled out.
      Ask FixBot
9 other people completed this guide.
Author
with
Jack
411 Reputation
3 Guides authored
Cal Poly, Team 8-46, Regan Winter 2010 Member of Cal Poly, Team 8-46, Regan Winter 2010
CPSU-REGAN-W10S8G46
5 Members
60 Guides authored
5 Guide Comments
Buenas abra el modo de reparar o puentear la placa de los botones start y selec ya que el flex se rompió
Good open the way to repairing or bypassing the plate and start buttons selec since the flex broke
Jesus Briones - Reply Share
Con ayuda de un cúter pela la terminales y solda nuevamente debes verificar si el flex tiene dos placas por ambos lados o solo es una
eshemoc - Reply Share
Any one know the right size shoulder buttons are for replacement ? Are they the same size as a ds lite R and L button ?
Philip Fuentes - Reply Share
Un tornillo se barrió, algún consejo para quitarlo?
Velfell Ackerman - Reply Share
Why are the outer shell screws SO FINNICKY? I had heard about the GB Micro being a hard device to disassemble, but the outer screws (four small ones) never go all the way in and I cannot figure out why.
DisasterEXE - Reply Share
Past 24 Hours: 11
Past 7 Days: 47
Past 30 Days: 252
All Time: 32,288
