Up to 20% off select tools
Game Boy Micro Battery Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
14
Past 7 Days:
53
Past 30 Days:
283
All Time:
4,256
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 3 minutes
Difficulty: Easy
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Community-Contributed Guide
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    Optional
    Any narrow flat-headed non-conductive tool will do
Introduction
Go to step 1 ↓
This guide will show how to safely replace the battery without damaging other parts of the board, or the battery itself.
    1. Game Boy Micro Battery Replacement, Remove the Cover: step 1, image 1 of 2 Game Boy Micro Battery Replacement, Remove the Cover: step 1, image 2 of 2
      • Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
      • Once the screw has been loosened, lift the cover off the back of the device.
      Ask FixBot
    1. Game Boy Micro Battery Replacement, Remove battery: step 2, image 1 of 3 Game Boy Micro Battery Replacement, Remove battery: step 2, image 2 of 3 Game Boy Micro Battery Replacement, Remove battery: step 2, image 3 of 3
      • Grip, and gently pull outwards on the cable as close to the battery connector as you can
      • Pull in level with the back cover in the direction as indicated by the arrow (not upwards, and not sideways), otherwise you could damage the connector, the cable, or just rip everything off.
      • When plugging the battery back in, make sure to use a non-conductive tool with a flat head to push the battery plug back into the connector, to avoid shorting the battery pins in the plug.
      Ask FixBot
2 other people completed this guide.
Author
with
SonoSooS
296 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 53
Past 30 Days: 283
All Time: 4,256
