Game Boy Display Lines/Bars
    1. Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: step 1, image 1 of 3 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: step 1, image 2 of 3 Game Boy Display Lines/Bars, Game Boy Display Lines/Bars: step 1, image 3 of 3
      • Remove the back housing by removing the 6 Tri-Point or Philip screws.
      • Note: The last 2 screws are in the battery compartment.
      Ask FixBot
    2. Game Boy Display Lines/Bars: step 2, image 1 of 2 Game Boy Display Lines/Bars: step 2, image 2 of 2
      • Carefully lift up the top half of the system. Be careful, there's a ribbon cable that connects the top and bottom half of the system.
      • Remove the ribbon cable for the next step.
      Ask FixBot
    3. Game Boy Display Lines/Bars: step 3, image 1 of 3 Game Boy Display Lines/Bars: step 3, image 2 of 3 Game Boy Display Lines/Bars: step 3, image 3 of 3
      • Now there will be screws that mount the board to the front, carefully unscrew these.
      • Now remove the board from the housing.
      • Now put the batteries back into the compartment, so you can test the screen while you fix it.
      • Reconnect the the board to back housing with the ribbon cable.
      Ask FixBot
    4. Game Boy Display Lines/Bars: step 4, image 1 of 1
      • You're now going to turn the contrast ( the slider on the left) all the way up, and take your soldering iron and gently move it back and forth on the ribbon cable below the screen.
      • Make sure not to touch the screen itself.
      • Note: There may be a rubber strip covering the ribbon.
      Ask FixBot
      • You will start to see the lines of pixels fade in and out, keep moving your iron back and forth until screen is completely black.
      Ask FixBot
7 other people completed this guide.
Mitchell
212 Reputation
1 Guide authored
2 Guide Comments
Hi, this is the second time I attempt this fix, the first time it worked perfectly. The problem is that with this second machine there's a couple of pixel lines that have not tickled back to black even though I have been patiently going over them for quite some time (2 rounds of 10-15 min) is there anything else that I could try or should I just go on over the same area until I see something happen? Thanks in advance
Jose Saura - Reply Share
Use this guide linked below understand where to place the iron under the screen. Step 4 doesn't seem to contain the proper images or details of this step here well enough.
https://www.youtube.com/watch?v=-OEXhxoT...
Bossman207 - Reply Share
Past 24 Hours: 10
Past 7 Days: 91
Past 30 Days: 347
All Time: 9,668
