Game Boy Color Screen Cover Replacement
Views: 27K
View statistics:
Past 24 Hours:
7
Past 7 Days:
56
Past 30 Days:
244
All Time:
27,244
Comments: 4
4 guide comments.
Go to guide comments
Completed: 27
27 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
The screen cover is the plastic window in front of the LCD screen. This guide shows how to replace the screen cover of the Game Boy Color.
Tools
  • Spudger
    4.9
    1. Game Boy Color Screen Cover Replacement, Battery: step 1, image 1 of 2 Game Boy Color Screen Cover Replacement, Battery: step 1, image 2 of 2
      • Locate the battery compartment on the back of the Game Boy Color.
      • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
      Ask FixBot
    2. Game Boy Color Screen Cover Replacement: step 2, image 1 of 1
      • Remove the batteries from the battery compartment.
      Ask FixBot
    1. Game Boy Color Screen Cover Replacement, Screen Cover: step 3, image 1 of 1
      • Carefully slide a razor blade under one of the corners of the screen cover.
      Ask FixBot
    2. Game Boy Color Screen Cover Replacement: step 4, image 1 of 1
      • Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
      • Continue gently pulling up on the cover until it is fully removed.
      Ask FixBot
27 other people completed this guide.
Nick Katsantones
1,169 Reputation
4 Guides authored
Cal Poly, Team 19-47, Regan Winter 2013 Member of Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Members
108 Guides authored
4 Guide Comments
bro, you mustn't to dismount the console to only remove the old lend
sdfsafas - Reply Share
You only need step 7 and 8.
h027299c - Reply Share
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Nick G - Reply Share
Yes that's true! I've seen repair videos where they do it the way you mentioned, much less of a headache
David Hannum - Reply Share
Past 24 Hours: 7
Past 7 Days: 56
Past 30 Days: 244
All Time: 27,244
