Game Boy Color Power LED Replacement
Views: 22K
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
159
All Time:
21,801
Comments: 13
7 comments on steps, 6 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 11
11 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will show you how to repair the Game Boy Color's power LED. The power led glows red when the device is turned on indicating that it is receiving power.
Parts
Tools
    1. Game Boy Color Power LED Replacement, Battery: step 1, image 1 of 2 Game Boy Color Power LED Replacement, Battery: step 1, image 2 of 2
      • Locate the battery compartment on the back of the Game Boy Color.
      • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
      Ask FixBot
    2. Game Boy Color Power LED Replacement: step 2, image 1 of 1
      • Remove the batteries from the battery compartment.
      Ask FixBot
    1. Game Boy Color Power LED Replacement, Back Housing: step 3, image 1 of 1
      • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
      Ask FixBot
    2. Game Boy Color Power LED Replacement: step 4, image 1 of 2 Game Boy Color Power LED Replacement: step 4, image 2 of 2
      • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
      Ask FixBot
    1. Game Boy Color Power LED Replacement, Motherboard: step 5, image 1 of 2 Game Boy Color Power LED Replacement, Motherboard: step 5, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
      Ask FixBot
    2. Game Boy Color Power LED Replacement: step 6, image 1 of 1
      • Gently lift the motherboard from the front housing.
      Ask FixBot
    1. Game Boy Color Power LED Replacement, Power LED: step 7, image 1 of 2 Game Boy Color Power LED Replacement, Power LED: step 7, image 2 of 2
      Ask FixBot
    2. Game Boy Color Power LED Replacement: step 8, image 1 of 1
      • Insert new LED into the circuit board.
      • Make sure that the LED is in the correct orientation. The longer leg of the LED is the positive end, while the shorter leg is the negative end.
      • The positive lead should go through the hole closest to the edge of the circuit board.
      Ask FixBot
    3. Game Boy Color Power LED Replacement: step 9, image 1 of 1
      • Solder the leads of the new LED to the circuit board.
      Ask FixBot
    4. Game Boy Color Power LED Replacement: step 10, image 1 of 1
      • Cut the excess ends of the LED legs using the wire cutters.
      Ask FixBot
8 other people completed this guide.
Alex Wu
1,786 Reputation
2 Guides authored
Cal Poly, Team 19-47, Regan Winter 2013 Member of Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Members
108 Guides authored
6 Guide Comments
what is the brass color looking thing under the soldering iron in step 7?
Soul Divide - Reply Share
That's called 'Desoldering Braid', it sucks up solder like a wick
John Smith - Reply Share
and what kind of LED are you using to replace?
This was great! Exactly what I needed with this. My GBC is looking good as new now!
Erick - Reply Share
Bw sure to research what LED colors work best. You often need to remove a resistor adjacent to the diode to allow for the colors white/blue/purple.
Evan Wilgosh - Reply Share
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 159
All Time: 21,801
