Game Boy Color Buttons Replacement
Views: 36K
View statistics:
Past 24 Hours:
8
Past 7 Days:
65
Past 30 Days:
262
All Time:
35,781
Comments: 9
6 comments on steps, 3 guide comments.
Go to guide comments
Completed: 29
29 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Sometimes the buttons on the device may stick or become unresponsive, requiring replacement. This guide shows how to replace buttons on the Game Boy Color.
Tools
    1. Game Boy Color Buttons Replacement, Battery: step 1, image 1 of 2 Game Boy Color Buttons Replacement, Battery: step 1, image 2 of 2
      • Locate the battery compartment on the back of the Game Boy Color.
      • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
      Ask FixBot
    2. Game Boy Color Buttons Replacement: step 2, image 1 of 1
      • Remove the batteries from the battery compartment.
      Ask FixBot
    1. Game Boy Color Buttons Replacement, Back Housing: step 3, image 1 of 1
      • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
      Ask FixBot
    2. Game Boy Color Buttons Replacement: step 4, image 1 of 2 Game Boy Color Buttons Replacement: step 4, image 2 of 2
      • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
      Ask FixBot
    1. Game Boy Color Buttons Replacement, LCD Ribbon Cable: step 5, image 1 of 3 Game Boy Color Buttons Replacement, LCD Ribbon Cable: step 5, image 2 of 3 Game Boy Color Buttons Replacement, LCD Ribbon Cable: step 5, image 3 of 3
      • Push up on the tabs on either side of the ribbon with a spudger.
      Ask FixBot
    2. Game Boy Color Buttons Replacement: step 6, image 1 of 2 Game Boy Color Buttons Replacement: step 6, image 2 of 2
      • Gently remove the ribbon cable from the port
      Ask FixBot
    1. Game Boy Color Buttons Replacement, Motherboard: step 7, image 1 of 2 Game Boy Color Buttons Replacement, Motherboard: step 7, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
      Ask FixBot
    2. Game Boy Color Buttons Replacement: step 8, image 1 of 1
      • Gently lift the motherboard from the front housing.
      Ask FixBot
    1. Game Boy Color Buttons Replacement, Buttons: step 9, image 1 of 1
      • Remove the rubber backing on each button grouping.
      Ask FixBot
    2. Game Boy Color Buttons Replacement: step 10, image 1 of 1
      • Remove the original buttons from the housing.
      Ask FixBot
29 other people completed this guide.
Nick Katsantones
1,169 Reputation
4 Guides authored
Cal Poly, Team 19-47, Regan Winter 2013 Member of Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Members
108 Guides authored
3 Guide Comments
Thank you for your information on repair of my color game boy.
just two things.
1. I had a hard time with the removal of the screws. Any tip on that would be helpful.
2. Where can I purchase replacement parts?
Thanks again for all of your help.
Ray Blasko
raymondblasko - Reply Share
In the tools needed it states Y0 screwdriver, but in step 3 it says Y1 which is not the same. Which one is the correct size?
blogcraft - Reply Share
I found either Y0 or Y1 works. The important thing is it's a small tri-wing.
Michael Schwern - Reply Share
Past 24 Hours: 8
Past 7 Days: 65
Past 30 Days: 262
All Time: 35,781
