Game Boy Cartridge Battery Replacement
Views: 85K
View statistics:
Past 24 Hours:
32
Past 7 Days:
171
Past 30 Days:
715
All Time:
84,529
Comments: 11
5 comments on steps, 6 guide comments.
Go to guide comments
Completed: 24
24 people have marked this guide "completed." Will you be next?
Favorites: 23
23 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 30 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Community-Contributed Guide
Introduction
Go to step 1 ↓
I will show you how to properly replace a battery in a gameboy cartridge game using a soldering iron
Parts
Tools
    1. Game Boy Cartridge Battery Replacement, Identification: step 1, image 1 of 3 Game Boy Cartridge Battery Replacement, Identification: step 1, image 2 of 3 Game Boy Cartridge Battery Replacement, Identification: step 1, image 3 of 3
      • The first step is to locate the problem. The Game Boy will give you a message such as this.
      • The battery you will need for this cartridge (an original game Boy game) is a CR2025 3V battery.
      Ask FixBot
    2. Game Boy Cartridge Battery Replacement: step 2, image 1 of 3 Game Boy Cartridge Battery Replacement: step 2, image 2 of 3 Game Boy Cartridge Battery Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Get your soldering iron heated, gather your tools, tweezers, and a Steel 3.8mm Screwdriver Security Bit
      Ask FixBot
    3. Game Boy Cartridge Battery Replacement: step 3, image 1 of 3 Game Boy Cartridge Battery Replacement: step 3, image 2 of 3 Game Boy Cartridge Battery Replacement: step 3, image 3 of 3
      • On the back side of the cartridge is a proprietary security bit and you will have to remove it.
      Ask FixBot
    4. Game Boy Cartridge Battery Replacement: step 4, image 1 of 3 Game Boy Cartridge Battery Replacement: step 4, image 2 of 3 Game Boy Cartridge Battery Replacement: step 4, image 3 of 3
      • Next you will need to slide the front face of the cartridge down to expose the motherboard
      • Remove the board from the plastic housing and clamp it in a vice with alligator clips for stability
      Ask FixBot
    5. Game Boy Cartridge Battery Replacement: step 5, image 1 of 3 Game Boy Cartridge Battery Replacement: step 5, image 2 of 3 Game Boy Cartridge Battery Replacement: step 5, image 3 of 3
      FixHub Smart Soldering Iron
      $79.95
      Buy
      • Use the soldering iron to gently heat the top tab while at the same time using the tweezers to pull the top tab away from the board
      • Then do the same to the bottom tab until the battery is free, be sure no to heat the board too much and only where it is soldered
      • Install the new battery in reverse order heating the solder first then setting the tabs on the hot solder, a little more solder may be needed to hold it in place, once it is cool check that the battery is secure
      Ask FixBot
    6. Game Boy Cartridge Battery Replacement: step 6, image 1 of 2 Game Boy Cartridge Battery Replacement: step 6, image 2 of 2
      • The final step is to set the board back into the plastic housing slide the cover shut and tighten the screw
      Ask FixBot
24 other people completed this guide.
Zane Hogue
841 Reputation
1 Guide authored
6 Guide Comments
Do you know what battery type is needed for older games like Pokémon Green?
There are no telling marks and it's notably smaller than the battery used for others I've fixed like Crystal or Red. I want to be sure I'm using the right replacement.
jackson3jonathan - Reply Share
The older cartridges should use the CR2025 the gameboy advanced cartridges sometimes use the CR1616, I buy my batteries off of amazon with the soldering tabs on them
Zane Hogue - Reply Share
When you change a Gameboy Cartridge battery, do you lose the currunt game save , THX
Ken Stock - Reply Share
Yes, anytime power is lost to the volatile memory the save is wiped.
Austin Fischer - Reply Share
The purpose of the battery in the cartridge is to retain stored memory such as saved games so if you remove the battery for replacement or the battery dies it will delete the saved game. Sucks really hope this helps
Past 24 Hours: 32
Past 7 Days: 171
Past 30 Days: 715
All Time: 84,529
