Introduction
This guide will give step by step instructions on how to remove and replace an existing battery in the Samsung Galaxy Tab S 10.5.
Place the plastic opening tool into the SD card slot or charge port.
Try in an upward motion until you see a separation between the tablet and back cover.
Tool used on this step:Tweezers$4.99
Using tweezers, peel back the green tape from the ZIF connectors on the two black ribbon cables.
Use a plastic opening tool to lift up the plastic clips on the ZIF connectors.
85 other people completed this guide.
21 Guide Comments
where is a good place to buy a replacement battery?
Artículo muy positivo: pasos muy bien detallados. Me ha resultado fácil la el cambio de batería. Gracias por tu colaboración.
Bought mine off of ebay
