Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Tools
Spudger4.9
Introduction
Go to step 1 ↓In this guide, you will learn how to completely take apart a Galaxy J3 Prime and put it back together again.
A video is also available for additional help.
Video Overview
Heat up the screen to loosen the adhesive.
You can use a iOpener or a hair drier, but make sure you don't get the phone too hot.
Remove the plastic bracket that will be visible when you pry up the screen.
Remove the screws on the back of the phone frame that are holding the housing of the phone together.
Now that all of the screws have been removed, pull up the frame with a screwdriver or spudger.
Be gentle so you don't break anything.
Disconnect the metal flex cable from the charging port.
Remove the Motherboard from the housing.
9 other people completed this guide.
3 Guide Comments
great guide, this really helped
thanks for your help, this has really helped
Best guide for a J3 out there professional and easy to follow
