Galaxy Book3 360 13" SSD Replacement
    1. Galaxy Book3 360 13" SSD Replacement, Remove the Screws: step 1, image 1 of 1
      • Flip the laptop over and remove each rubber shoe
      • Use a Philips screwdriver to care fully remove each screw
      Ask FixBot
    2. Galaxy Book3 360 13" SSD Replacement, Remove the Case: step 2, image 1 of 2 Galaxy Book3 360 13" SSD Replacement, Remove the Case: step 2, image 2 of 2
      • After removing the screws carefully pry open the case starting on the top right hinge.
      • There is a clip in the center of the laptop , when the edges are completely removed lift carefully to unclip the center.
      Ask FixBot
    3. Galaxy Book3 360 13" SSD Replacement, Replace the SSD: step 3, image 1 of 1
      • Carefully remove the screw holding down the SSD.
      • Lift the SSD until it is at about a 10-degree angle and then slide it out of the socket.
      • Slide in your new SSD, and follow the previous steps in reverse.
      Ask FixBot
7 other people completed this guide.
Dan
5,252 Reputation
9 Guides authored
5 Guide Comments
Are you sure for the second slot it is 2280 and not 2230?
Jeremy Asher - Reply Share
How can I be sure for my NP750QFG that it's 2280 and not 2230?
Any advice?
Galaxy book 3 360 15.6" inch variant support Gen 3 NVMe 2280 type ssd like WD Black SN770
Biswajit Shial - Reply Share
Mine is 15.6 size and it's for the second slot, the 13" I think didn't have a second slot.
How do I know i it's for 2230 or 2280?
I opened my Book3 Pro 360 5G and the SSD is covered by a metal shield. How do I remove this shield to gain access to the SSD and slot?
Lloyd Franklin - Reply Share
Past 24 Hours: 10
Past 7 Days: 54
Past 30 Days: 282
All Time: 18,715
