GT Aggressor Pro Mountain Front Wheel Spoke Replacement
  1. GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: step 1, image 1 of 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: step 1, image 2 of 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement, Front Wheel Spoke: step 1, image 3 of 3
    • Placing your bike on a stand or having a friend hold the bike will make the repair easier to perform.
    • Pull the quick-release lever on the front wheel of the bike and turn it to loosen it.
    Ask FixBot
  2. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 2, image 1 of 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 2, image 2 of 2
    • Remove the quick-release lever.
    Ask FixBot
  3. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 3, image 1 of 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 3, image 2 of 2
    • Remove the fork from the axle of the wheel.
    Ask FixBot
  4. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 4, image 1 of 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 4, image 2 of 2
    • Remove the cap from the Presta air valve that is located between the spokes on the rim.
    Ask FixBot
  5. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 5, image 1 of 1
    • Push up on the Presta valve to release the air in the inner tube.
    Ask FixBot
  6. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 6, image 1 of 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 6, image 2 of 2
    • Twist the valve to remove the nut from it.
    Ask FixBot
  7. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 7, image 1 of 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 7, image 2 of 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 7, image 3 of 3
    • Remove the tire and inner tube from the rim.
    • It is possible to do this with your hands but using a tire lever would simplify the process.
    Ask FixBot
  8. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 8, image 1 of 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 8, image 2 of 3 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 8, image 3 of 3
    • Loosen the spoke by using the spoke wrench.
    • Use a flat head screwdriver to remove the screw corresponding to the damaged or broken spoke.
    Ask FixBot
  9. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 9, image 1 of 1
    • Use a T25 screwdriver to remove the six 10.0 mm screws from the disk brake rotor.
    Ask FixBot
  10. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 10, image 1 of 2 GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 10, image 2 of 2
    • Unthread and remove the spoke from the rim and the hub.
    • Make sure to look at the alignment of the spoke removed in order to put the new spoke back on the same way.
    • The spoke will come out of the hole.
    Ask FixBot
  11. GT Aggressor Pro Mountain Front Wheel Spoke Replacement: step 11, image 1 of 1
    • Thread the new spoke into the rim.
    • Make sure the alignment/placement of the new spoke is the same as the old one.
    Ask FixBot
Thank you for using our guide. Enjoy getting back on the trails or roads!
1 Guide Comment
Hello! can you please share the spoke length/specs. Thank you
amine - Reply Share
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 117
All Time: 1,790
