GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair
    1. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair, GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 1, image 1 of 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair, GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 1, image 2 of 2
      • Take out the front metal grill.
      • Flick open the metal piece, located by the side of the cover, to get the front and back of the grille unlocked from each other.
      Ask FixBot
    2. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 2, image 1 of 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 2, image 2 of 2
      • Turn the knob counterclockwise to take out the blade cap.
      Ask FixBot
    3. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 3, image 1 of 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 3, image 2 of 2
      • Loosen the plastic nut on the rear grille and then take the rear grille out.
      Ask FixBot
    4. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 4, image 1 of 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 4, image 2 of 2
      • Unscrew the plastic on the fan motor, and gently pull the slide open: There are four screws, proceed to taking off the plastic plates.
      Ask FixBot
    5. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 5, image 1 of 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 5, image 2 of 2
      • Apply machine oil onto any rusted parts, making sure you apply it around, but not in, the fan rotor.
      • Let the oil sit for about 5 minutes
      • Do not spill the oil on the surface or into the rotor.
      Ask FixBot
    6. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 6, image 1 of 2 GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 6, image 2 of 2
      • Carefully place the plastic plate properly on the surface of the fan rotor.
      • Make sure the screws align with the holes on the fan motor, then proceed to screw.
      Ask FixBot
    7. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 7, image 1 of 1
      • Place the fan rear grille back into its original position and pick up the plastic grill nut.
      • Screw the rear grille onto the fan motor.
      Ask FixBot
    8. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 8, image 1 of 1
      • Place the blade back onto the motor pin, making sure it sits on the edges of the fan.
      Ask FixBot
    9. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 9, image 1 of 1
      • Take the circlip and tighten it well onto the blade.
      Ask FixBot
    10. GRAVITTI 16" 3 SPEED OSCILLATING STAND FAN Repair: step 10, image 1 of 1
      • Pick up the front grille and align it with the metal piece around the fan.
      • Lock the metal piece, so that both the front and rear grilles are locked.
      • If the metal pieces do not align, you will have issues locking the grilles to each other.
      Ask FixBot
3 other people completed this guide.
TUOYO FABIYI
262 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 124
All Time: 1,767
