GPD Win Battery Replacement
Views: 8.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
47
Past 30 Days:
177
All Time:
8,398
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Follow this guide to learn how to replace the battery of your GPD Win. Be sure to power off your device prior to starting the guide.
Tools
    1. GPD Win Battery Replacement, Battery: step 1, image 1 of 1
      • Shut down your GPD Win.
      Ask FixBot
    2. GPD Win Battery Replacement: step 2, image 1 of 1
      • Remove SD card and duct cover.
      Ask FixBot
    3. GPD Win Battery Replacement: step 3, image 1 of 1
      • Remove the six PH #00 screws on the back of the GPD.
      Ask FixBot
    4. GPD Win Battery Replacement: step 4, image 1 of 3 GPD Win Battery Replacement: step 4, image 2 of 3 GPD Win Battery Replacement: step 4, image 3 of 3
      • Carefully insert the pry tool between the keyboard and case.
      • Move the tool around the edge until every clip is released.
      • Carefully lift the back half of the case.
      • You'll see a small ribbon connector on the right. Use your pry tool to remove it by lifting up.
      • On the right, you'll see another white connector going to the battery. Use the pry tool and pull back on the connector to release it.
      Ask FixBot
    5. GPD Win Battery Replacement: step 5, image 1 of 3 GPD Win Battery Replacement: step 5, image 2 of 3 GPD Win Battery Replacement: step 5, image 3 of 3
      • Separate the two halves of the device.
      • Use the pry tool and slowly and carefully separate the adhesive from the back of the case.
      • Remove old battery.
      Ask FixBot
    6. GPD Win Battery Replacement: step 6, image 1 of 2 GPD Win Battery Replacement: step 6, image 2 of 2
      • Use two to three strips of the double sided tape and apply it to the back of the battery.
      • Line up the battery with the lines on the case and the connector on the right.
      Ask FixBot
3 other people completed this guide.
1 Guide Comment
At the moment, the Shenzhen Zero Five Battery Company replacement comes with two wires crossed. You'll need a small metal pick to pry the clips open enough to pull the conductors out and swap them over. It should be red, yellow, black. I've performed the modification and can confirm it works after switching the contacts.
Dr. Nick - Reply Share
Past 24 Hours: 2
Past 7 Days: 47
Past 30 Days: 177
All Time: 8,398
