GMMK-BRN Keyboard Switch Replacement
    1. GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: step 1, image 1 of 2 GMMK-BRN Keyboard Switch Replacement, Keyboard Switch: step 1, image 2 of 2
      • Unplug the keyboard from your device.
      • Place the keyboard on a clean workspace, along with the tools required.
      Ask FixBot
    2. GMMK-BRN Keyboard Switch Replacement: step 2, image 1 of 3 GMMK-BRN Keyboard Switch Replacement: step 2, image 2 of 3 GMMK-BRN Keyboard Switch Replacement: step 2, image 3 of 3
      • Use your fingers or a keycap remover and pull directly upward to remove the keycap.
      • It is possible to damage the keycap if not pulled directly upwards.
      Ask FixBot
    3. GMMK-BRN Keyboard Switch Replacement: step 3, image 1 of 2 GMMK-BRN Keyboard Switch Replacement: step 3, image 2 of 2
      • Use the switch remover to push the tabs in on the opposite sides of the switch.
      • Firmly pull the switch upwards.
      • If the switch is pulled at an angle, there is a risk to damaging the switch.
      • The switch may not come out easily, so more force may be required.
      Ask FixBot
    4. GMMK-BRN Keyboard Switch Replacement: step 4, image 1 of 3 GMMK-BRN Keyboard Switch Replacement: step 4, image 2 of 3 GMMK-BRN Keyboard Switch Replacement: step 4, image 3 of 3
      • Align the pins on the keycap with the ones inside the keyboard.
      • Insert the switch, and press down firmly until a click is heard.
      Ask FixBot
    5. GMMK-BRN Keyboard Switch Replacement: step 5, image 1 of 3 GMMK-BRN Keyboard Switch Replacement: step 5, image 2 of 3 GMMK-BRN Keyboard Switch Replacement: step 5, image 3 of 3
      • Align the cross of the keycap with the cross of the switch.
      • Push the keycap down firmly to reattach.
      Ask FixBot
    6. GMMK-BRN Keyboard Switch Replacement: step 6, image 1 of 2 GMMK-BRN Keyboard Switch Replacement: step 6, image 2 of 2
      • Plug the keyboard back into your device.
      • Turn you device on and do a test to see if the new switch works.
      Ask FixBot
Kyle Lieu Dang
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 32
All Time: 1,036
