Up to 20% off select tools
GK61 Keyboard Keycap/Switch Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
129
All Time:
2,755
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
In this guide, I will show the process of repairing and replacing keycap switches on the GK61 Keyboard mechanical keyboard.
Over a period of time, though keyboards look fine on the exterior, the little crevices collect hair, oils and dust which will affects its performance. This guide will show how easy it is to repair your mechanical keyboard.
    1. GK61 Keyboard Keycap/Switch Replacement, Keycap/Switches: step 1, image 1 of 1
      • Unplug the keyboard.
      • When the keyboard lights are off, it indicates that the keyboard is turned off.
      Ask FixBot
    2. GK61 Keyboard Keycap/Switch Replacement: step 2, image 1 of 3 GK61 Keyboard Keycap/Switch Replacement: step 2, image 2 of 3 GK61 Keyboard Keycap/Switch Replacement: step 2, image 3 of 3
      • Use a keycap puller to remove the top and bottom of the keycaps from the keyboard.
      • When pulling the keycap, make sure to apply pressure until you hear a click sound from the keycap.
      • Remember when using a keycap puller, place it on a key in a vertical position.
      Ask FixBot
    3. GK61 Keyboard Keycap/Switch Replacement: step 3, image 1 of 1
      • After removing all the keycaps, put it in a bowl.
      • You can either use alcohol wipes or water to clean your keycaps.
      Ask FixBot
    4. GK61 Keyboard Keycap/Switch Replacement: step 4, image 1 of 1
      • Dry the keycaps on a rag or paper towel.
      • Remember to let your keycaps dry for about 5-10 minutes after cleaning.
      Ask FixBot
    5. GK61 Keyboard Keycap/Switch Replacement: step 5, image 1 of 1
      • Using a hand held vacuum cleaner remove any excess dust, hair, and oils.
      • Tilting your keyboard will also help for a deeper clean
      • If you cannot locate a hand held vacuum cleaner, a compressed air duster will also work.
      Ask FixBot
    6. GK61 Keyboard Keycap/Switch Replacement: step 6, image 1 of 3 GK61 Keyboard Keycap/Switch Replacement: step 6, image 2 of 3 GK61 Keyboard Keycap/Switch Replacement: step 6, image 3 of 3
      • Using a Q-Tip with rubbing alcohol, gently clean and rub the crevices around the plate of the keyboard.
      • Make sure not to pour rubbing alcohol onto your keyboard. Doing so may cause severe damage to the keyboard.
      Ask FixBot
    7. GK61 Keyboard Keycap/Switch Replacement: step 7, image 1 of 3 GK61 Keyboard Keycap/Switch Replacement: step 7, image 2 of 3 GK61 Keyboard Keycap/Switch Replacement: step 7, image 3 of 3
      • Using a switch puller, pull the keyboard switch from the top and bottom of the switch.
      • Remember to always pull straight up to fully remove the switch.
      Ask FixBot
    8. GK61 Keyboard Keycap/Switch Replacement: step 8, image 1 of 2 GK61 Keyboard Keycap/Switch Replacement: step 8, image 2 of 2
      • Grab a replacement switch to replace the broken switch.
      • Push the switch straight down into the socket of the switch.
      • To avoid any damages, make sure to always push straight down and not in any other direction.
      Ask FixBot
    9. GK61 Keyboard Keycap/Switch Replacement: step 9, image 1 of 3 GK61 Keyboard Keycap/Switch Replacement: step 9, image 2 of 3 GK61 Keyboard Keycap/Switch Replacement: step 9, image 3 of 3
      • After drying the keycaps, put the keycaps back into their sockets.
      • Align the keycap with the socket of the switch and push straight down with a bit of pressure.
      • When pushing straight down, you will hear a click sound that will indicate that the keycap has been placed.
      Ask FixBot
Author
with
Alexander Truong
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 129
All Time: 2,755
